Customize Dashboard what would i do if i want DD?
Old Sep 28, 2010 | 12:57 AM
lilvi3tboyzz's Avatar
so basically i got a wood edition dashboard instead of normal silver. So what would i do if i want DD? thanks
Old Sep 28, 2010 | 06:42 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Replace both the shifter trim plate and the center trim plate with aluminum pieces, or you can get creative with a dremel and re-use a decent portion of the wood trim - my DDin shopping/resource sticky has links to a post from somebody who built his own DDin trim. You will still need to pick up the a/c controls though, but a link to get those is also included in the same sticky.
Good luck, and document the procedure!
Old Sep 29, 2010 | 12:14 AM
so can i cut my own DD from the wood trim ?
Old Sep 29, 2010 | 04:24 AM
More or less, check out the post I referenced. Quality depends on your skill.
Old Oct 3, 2010 | 09:46 PM
thanks can you link the post or if its too much then nvm thanks again
Old Oct 4, 2010 | 02:36 AM
https://g35driver.com/forums/audio-v...tock-face.html
Old Oct 5, 2010 | 03:00 AM
thanks,
another question, Since you cut ur wood trim dd. So does you still have Sat? and does that dd have an Aux cord?
thanks,
another question, Since you cut ur wood trim dd. So does you still have Sat? and does that pioneer or andy Dd have an Aux cord out ?
Old Oct 5, 2010 | 08:25 AM
WhosUrBuddiee's Avatar
Swap out all your wood for silver, then buy the JDM DD finisher
Old Oct 5, 2010 | 10:42 AM
Originally Posted by lilvi3tboyzz
thanks,
The stock SAT tuner doesn't work with aftermarket radios. The antenna *may* be capable of being used with an aftermarket SAT tuner, but the one guy who was going to test this out never got back to me.
99% of aftermarket radios these days have AUX inputs/line outputs. Some are on the front, some on the rear.
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
