Viper 5902 responder & remote start install price
on
The '03s are cake - no smart key and no data module required. On my '04 I used a $25 556U from DEI and the valet key that I never planned on using. There are more expensive modules that don't require a key if that is a priority to you.
The only other unusual thing about Infinitis (and Nissans) is that there is a second starter wire - make sure they hook that up as well or you could have intermittent remote start problems in cold weather.
Ya, i only have one key for my G since I bought it used..
I bought the Xpresskit XK09 if hope that will work..
on
on
A data module will not provide the same dependability as hard wiring the door locks. When it comes to security, at least in my opinion, the door locks should ALWAYS be hard wired. As an added benefit on the G if you hard wire the door locks you also get remote window control. It's really a no brainer....
on
I will go ahead and have him hard wire it.
Edit: How do you go about getting the remote window control?
I just spoke with my installer and he said that it might be an extra work if I have him do the window control. Please let me know so I know how to negotiate with him about the price. Thanks.!
on
How about the trunk release control?
Speaking of that - you should always tell the installer BEFORE you pay that you want to check out the install before they put anything back together. If your installer knows you want to inspect his work before he puts the car back together hopefully he will go the extra mile.
When you inspect the installation you should not be able to see anything when sticking your head up from under the dash - don't let them get away with simply "hiding" the alarm above the black plastic trim piece under the dash!
on
So I just got everything all working now..
When I went to my installer's shop the other day he was only able to get the remote start working,but he did not hard wire the doors, windows,and trunk.
Now , I just came back from his shop and now everything is all working..
I actually watched him the whole time because I will be upgrading my HU and speakers really soon. He did do everything cleanly. No wires hanging around.
He is only a bit cheaper compared to the rest of the shops here in my area.
Overall I am satisfied with the install.![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
Thanks a lot for your help Kpierson!!!
