Cap or not to cap, capacitor
Old Nov 9, 2010 | 11:27 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Zenclosures seal the trunk and woofer from the cabin, so there's that, but other than that, they're a good price for a vehicle-specific fit box.
The stock speakers are mediocre at best, but they're generally considered the least bad part of the system (which isn't saying much), but the bose amp sucks. It's got a built-in EQ that sucks the bass out whenever the volume goes up, and is weak.
Old Nov 9, 2010 | 11:46 AM
mjholla19's Avatar
I have never thought about the zenclousures that way but now that I do that is true
I will swap out my stock amp and speakers see how that sounds
Old Nov 9, 2010 | 02:04 PM
mjholla19's Avatar
Originally Posted by Wrathernaut
I have:
JL 300/1v2 (Speakers)
JL 500/1v2 (Sub)
4080 Enclosure
JL 10w6v2
BA Pro60se's up front
BA SC65's in the rear
Pioneer Z110BT
sounddeadenershowdown.com CLD tiles in the trunk and on one door (didn't finish before deploying)
dynamat is crap, but it's easy to buy locally, but the SDS CLD tiles are much better in terms of price, adhesion and vibration dampening.
You forgot to say 1 farad capacitor lol
Old Nov 9, 2010 | 07:22 PM
^ That's it, you're going on my list.
Old Nov 12, 2010 | 09:11 PM
Gee35init's Avatar
Helps maintain voltage, when you have sudden voltage drops ie serious bass note, it also aids in power factor correction depending on inductive/capacitive load. They definatly help, with out it all the accessories in the car and lights dim when you get a voltage drop across the load.
In my opinion lol
Old Nov 13, 2010 | 03:28 AM
^ sounds like the marketing speak to me. A "serious bass note" lasts more than the 1/20th (being generous here) of a second that your cap would actually be providing power.
Old Nov 13, 2010 | 01:35 PM
35Alive's Avatar
Good information. Sounds like keeping a capacitor out of your system will not only save you money, but also your alternator.
Old Nov 13, 2010 | 03:58 PM
Money only, the impact of a cap is very minimal, and I would never say it was directly responsible for an alternator going out, unless it was poorly installed or the cap failed (but that's what fuses are for).
Again, that's why keeping it simple and done well is the best way to go. Less parts = less chances for failure.
Old Nov 13, 2010 | 04:16 PM
Gee35init's Avatar
I don't even have a system, I'm just saying what I learned in school. Also my friend had his system with out a cap and the lights in the car and the headlights would dim when the speakers hit low bass notes. He installed a capacitor and it fixed the issue. I'm pretty sure that's all they do, it doesn't make your speakers louder or sound better or your system more powerful, which in my opinion is the most common misconception with caps!!
Old Nov 13, 2010 | 05:03 PM
^ In that situation, I would guess it was an amp with an unregulated power supply, in which case, you're spending $100 on a cap to cover the $10 you saved by buying a cheap amp.
Old Nov 19, 2010 | 02:44 PM
615brian's Avatar
Talking
Originally Posted by hkazmi
So everyone says Capacitors are not needed (as I recently found out).
After revising my Electrical 101, here is my rant.
Capacitor will protect factory alternators.
Every time the amp wants more current, the battery and alternator will see a drop in resistance on the entire 12V bus on your vehicle. If the battery is unable to provide that current, your alternator will try to. This means that your alternator will have peaks of higher current running at those times.
Heat generated is a squared function of current, meaning if your alternator is providing 1A constant, instead of peaks of 0.6A --> 1.4A, the 1.4A peaks will generate more heat in bursts within the coil. This will in no doubt shorten the life of your alternator. Now if you put in a Capacitor, the current bursts that were being provided by your alternator will be shared with the capacitor, your alternator will have load spread over time.
Given the choice, I would generate less current over a long period as the function for heat generated is ((I^2)*r*t), where I is the current, so if current goes up, more heat is generated as current is squared, time on the other hand is not squared.
So IMO, if you feel you are gonna strain the alternator, put in a capacitor.
If you got a huge alternator, skip it.
Please let me know of gaps in my analysis.
most of the time people get ripped off on capictors... its either a crappy one or they shouldnt have gotten one in the first place. if your car lights are blinking when your bumping try a yellow top battery with a big reserve capcity. other wise me or other people who have had descent systems use a battery instead of a capcacitor for just a daily system ( not professional show use ) but yes like you said an alternator upgrade is way better for the long run... more pricey than a cap but since they are make 280 amp and 320amp alt. so small now its just better overall. i had 3 15's in my titan with 6k watts with just a 225amp alternator with no capacitors. but for my g im just doing 1 12 with 2500 watts with an extra battery.. add another batter instead of a capacitor..
Old Nov 19, 2010 | 03:36 PM
Gee35init's Avatar
Not to disprove anything you said but the unit of measurment for current is an amp
seagrasser
May 3, 2022 09:43 AM
g.spot
May 9, 2016 10:54 PM
vamarris
Sep 26, 2015 12:56 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
