Upgrade your stocks using your stocks DIY
Old Oct 28, 2004 | 03:49 PM
RamboRami's Avatar
G35driver.com Moderator
Re: Upgrade your stocks using your stocks DIY
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
Old Nov 22, 2004 | 12:22 AM
spadak's Avatar
I wanted to replace my stockers but I don't like cutting wires so here's what I did to get around that problem...
Here is the stock bose, has the mounting holes and the connector interface you'd want for both the front and the rear speakers.
2004 DG G35 Coupe, Premum, Sport, Aero.
Old Nov 22, 2004 | 12:24 AM
spadak's Avatar
Connector interface
Old Nov 22, 2004 | 12:26 AM
spadak's Avatar
First start off by cutting each spline attaching the Bose speaker to the plastic housing as shown.
Old Nov 22, 2004 | 12:27 AM
spadak's Avatar
Next remove the old Bose speaker with the wimpy magnet
Old Nov 22, 2004 | 12:30 AM
spadak's Avatar
Using either screw or JB Weld (or equivalent) attach your new aftermarket speaker to the Bose housing
Old Nov 22, 2004 | 12:31 AM
spadak's Avatar
New speaker mounted to Bose housing
Old Nov 22, 2004 | 12:36 AM
spadak's Avatar
Finally solder the speaker wire to the stock speaker connector as shown, (notice the nice big magnet), be sure you have the correct polarity shown here (red - positive, black - negative).
This speakers are seperates with two tweeters, I left one in the center cone, and the other will go in the stock tweeter location. No cutting, just mount and click into the stock harness. Have fun...
Old Nov 22, 2004 | 09:03 AM
my_Gthang's Avatar
What size is the stock speaker and what size did you replace it with?
Old Nov 22, 2004 | 12:11 PM
spadak's Avatar
Stocks are 6.5, I replaced the fronts with 6.5 inch separates, and the rears with 6 inch coaxials.
Old Dec 8, 2004 | 01:34 PM
LD500's Avatar
The JPG links don't seem to work anymore
Daniel k.
Nov 3, 2015 09:52 AM
Nate_G35
Aug 25, 2015 11:30 AM
Blakelyg35
Aug 15, 2015 12:12 PM
newg37
Jul 26, 2015 09:32 AM
