Which steering wheel interface?
Old Nov 15, 2010 | 11:52 PM
Raaaaaaaandy's Avatar
Which steering wheel interface should I go with? I am getting the Pioneer 920BT in and 06 coupe w/premium... I'd like to still be able to use my phone and mute buttons for something if possible.
I spoke with friend who are installers and have gotten 2 different recommendations, the PAC-SWI and Metra Axxess ASWC.
Which one and why?
Thanks in advance Wrathernaut
Old Nov 16, 2010 | 11:26 AM
spoolinupblue's Avatar
I believe Wrathernaut uses the PAC one.
I dont use one, as I never did use the buttons on the steering wheel.
Old Nov 16, 2010 | 03:31 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yep, I have no experience with other brands, and there's no significant price difference, so go with the one that has handy instructional videos and good record on here.
PAC SWI.
And yes, all the buttons can be mapped to whatever your headunit supports, which in the X920BT is basically everything, even the voice recognition.
Old Nov 17, 2010 | 10:43 AM
ungarocd's Avatar
The new ASWC from Axxess is the best out right now.
Old Nov 17, 2010 | 12:37 PM
Far from the best for a radio that supports a voice recognition button. I just looked through the ASWC installation manual, and it doesn't look like it can map a button to the voice recognition feature on the AVIC X920BT or Z110/Z120BT radios, so I definitely wouldn't use it with either of those radios.
For most others though, looks pretty good, since you don't have to solder in any resistors.
One other thing, the website it says to go to to see if the car will auto-program doesn't say if our car auto-programs or not, and it's manual programming looks to be slightly more complicated due to having to bypass the auto-programming search, but not substantially so.
They do claim it can be updated, though, so perhaps in the future it'll support the voice recognition button.
Old Nov 17, 2010 | 12:51 PM
rcdash's Avatar
You can remap with the ASWC. Not sure what manual you are looking at? Link?
Old Nov 17, 2010 | 02:44 PM
blazeplacid's Avatar
seems like the axxess controller is the way to go
seems to work almost perfect with nissan/infiniti
Old Nov 17, 2010 | 06:13 PM
http://assets.sonicelectronix.com/ma...metra/aswc.pdf
No Voice Recognition in the mappable functions: (and before anybody asks, no, it can't control the a/c functions towards the bottom of the list)
ASWC's mappable functions:
1. Volume Up
2. Volume Down
3. Seek Up/Next
4. Seek Down/Prev
5. Source/Mode
6. Mute
7. Preset Up
8. Preset Down
9. Power
10. Band
11. Play/Enter
12. PTT (Push To Talk)
13. On Hook
14. Off Hook
15. Fan Up
16. Fan Down
17. Temp Up
18. Temp Down
SWI-PS's Mappable Functions:
1. Volume Up
2. Volume Down
3. Mute
4. Track Up/ Seek Up
5. Track Down/ Seek Down
6. Source
7. Preset Up/ Disc Up
8. Preset Down/ Disc Down
9. Band
New functions added for Pioneer
10. Phone Status, Rev. 1.6.7
11. Answer Call, Rev. 1.6.7
12. End Call, Rev. 1.6.7
13. Voice Recognition, Rev. 1.6.8
So with a AVIC Z110BT, Z120BT, or X920BT, the SWI-PS is the one to get *right now*.
If the ASWC gets the voice recognition via an update later, it could be the one to recommend.
Old Nov 19, 2010 | 01:52 PM
rcdash's Avatar
I think you are assuming that the phone functions of the ASWC (#s 12-14) wouldn't function to support voice recognition in a headunit. PTT in particular. Each head unit application may be different of course. The PAC unit has lots of complaints about delays in sending signals, which is why I decided against it.
Old Nov 19, 2010 | 02:35 PM
I believe that 13 (answer) and 14 (disconnect) on the ASWC work fine, but you're right that I'm assuming that PTT means push to talk for push-to-talk enabled phones, instead of assuming it means "push to talk to the headunit to give it commands", but I think it's a solid assumption.
I've had no issues with lag on commands with the SWI-PS, but I've only used 1.6.7 or newer firmware in my installations and soldered all connections.
jsimonk
Dec 22, 2023 03:49 PM
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
derres
Aug 28, 2015 03:27 PM
Karnicle
Jul 23, 2015 05:08 AM
