Molex Pin Out Diagram
Old Apr 15, 2011 | 03:28 PM
ATL_Red_G35's Avatar
Well, long story short, my dumbass installer knicked couple wires when he ran the speaker wires through the molex. So my windows up and the lock/windows control module Lighting is intermittent.
I found out it was the issue with the connection at the Molex connector because when I wiggle the wirelooms, the power comes off and on.
Therefore, does anyone have the pin out digram so I can check to make sure if these wires are the ones that cause the issue and not the others (while I have the door detached and the molex out?
Oh, and he went MIA as well as the shop went belly up so I have noone to go after
Thanks,
The bottom set of wires seem to be okay. The top 4 are brazed and the light blue wire is the one that being knicked the most with about half of its copper threads cut.
Old Apr 15, 2011 | 07:29 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
I'd cut the bad section out of that blue wire and make a more solid connection there.
Just fix the obviously damaged wires one at a time and you shouldn't have to worry about the pin-out.
Old Apr 15, 2011 | 07:49 PM
Yea. I fixed the obvious blue wire but that didn't solve the problem. Just by wiggle the connector a lil, I'm loosing the power. Further troubleshooting shows that I'm loosing the 9V on a small red wire (at the controller).
I'll verify which red wire it is later. I don't know if it's the only one that's intermittent or there's more. For all I know, the 9V may be powering the entire module (button LEDs, under door lights, and windows up/down enable. If that's true, then it's an easy fix.
We will see. More feedback later. Also, any suggestion is welcomed.
Thanks,
master111
Oct 6, 2015 01:36 AM
dcsbh1
Oct 1, 2015 03:15 PM
Cory Dalton
Sep 23, 2015 08:08 PM
AuAltima3.5
Drivetrain
Sep 13, 2015 10:36 AM
.cakestar
Aug 28, 2015 04:50 AM
