Replacing Bose sub
Replacing Bose sub
Im right now looking at subwoofers to replace the bose sub. Would this JL audio 8in Sub fit in the same place where the bose one is
http://mobile.jlaudio.com/products_s...p?series_id=37
if not what would you recommend?
https://g35driver.com/forums/audio-v...surements.html
It looks like it'll fit in the stock mounting hole just fine:
(A) Diameter Overall: 8.5 in. / 216 mm
(B) Mounting Hole Diameter: 6.94 in. / 176 mm
(C) Bolt Hole Circle: 7.39 in. / 188 mm
(D) Magnet Diameter: 5.79 in. / 147 mm
(E) Mounting Depth: 6.83 in. / 173 mm
It's taller than the stock unit by about two inches, but I think it'll still fit between the deck and the trunk carpeting trim.
I'm more worried that it won't fit under the Bose grille on the back though, there was about 1" of stuff above the mounting surface with the Bose sub, while the JL looks like it's got that much + whatever the excursion of the JL does when under power (.75 inches). I did not measure the distance above the deck that the factory grill rises, but it looks like it'll be very close.
I want quality bass. I'm looking for the best i can buy and that wont sound like crap. Bass means alot since i listen to house and dubstep alot
If that's what you're after, you'd probably be better served by a ported 10", but I understand not wanting to give up any space.
Im not looking for a loud bass but i am looking for a clear and quality sound. and yes i would love a 10. But im just wanting to look for a good quality 8' sub.
I also do not want of 17 lbs(freakin extra rim!) of extra weight in my weekend racer...so to each its own?
There's also no reason to knock product down because it lists for $179 and not $500. Since I got my Pioneer for $80 shipped I really doubt that JL will sound 6 times better.
I wouldn't put ANY sub in the rear deck. It'll rattle like hell and sound like crap.
1 or 2 of these would do http://www.sonicelectronix.com/item_...-SWR-843D.html
Pioneer TS-SW841D
Frequency Response: 30Hz to 1,500 Hz
JL 8w7
Frequency Response: 23Hz - 250 Hz
Tell me, how many shallow mount 8" Pioneers do you need to hit a 25Hz bass note? 6? 8? Infinity? They NEVER will. Where's the value in that?
There's no reason to use a shallow mount unless it's absolutely necessary.
As for weekend racer... I can remove my ~50lbs of enclosure and sub in about 2 minutes
You don't lose much space with a boxology (formerly known as 4080) enclosure at all, and it comes out in 2min or less if you really need the space behind a wheel to fit something in there.
Oh no, here comes the facts:
Pioneer TS-SW841D
JL 8w7
Pioneer TS-SW841D
JL 8w7
Pioneer's basket is also designed to be mini enclosure, which is a huge benefit in free air installation. I actually hooked it up to home stereo to test it-no baffle at all. It had a nice kick from ancient 30 watt receiver without any crossover ! Nothing you can expect from a sub which is just sitting on the floor.
I do not listen to ghetto "Bass is tha ****e" recordings to care about 25Hz notes. Those 25 hz at what? -6 db?-8db? Did you see the actual curve? Sub is going into factory spot along with few layers of Fat Mat and will sound great. No box!
My first sound off was in 1997 with Pioneer sub and I love their stuff. I was turned off JL products by that bald fvck working for JL who was ****eing on car audio forums about the same time.
I do not deny that JL will sound better, but definitely not $400 better...And I own home audio system pushing well into 5 digits...including 1978 Denon turntable
I reiterate-to each it's own. I just want to present an alternative to other G members.
