Just got my double din
Old Dec 8, 2004 | 03:52 AM
sebass04's Avatar
Hey people... I just got my double din.. I'm gonna install this as soon as I get me xmas gift which is my deck.. it's a pioneer Deh-860mp premier.. I went with that coz I like the titanium match with my din.. but my question is will the stock amp be good enough to match the deck? or do I need to get new amp? oh btw I have a 2003 sedan..
Old Dec 8, 2004 | 05:04 AM
G35Lin's Avatar
Multi-Spoked Mod
a new amp for....... ur speakers? or ur deck??
Ed
Old Dec 8, 2004 | 01:34 PM
Forte's Avatar
Where did you get yours from? If I may ask.
Old Dec 8, 2004 | 02:11 PM
sebass04's Avatar
amp for my speakers... do I need it or it'll be just fine with the stock amp?
[QUOTE]Where did you get yours from? If I may ask.
I got mine at japanparts.com and they shipped it within 2 weeks.. everything that you need is there including the AC controller..
Old Dec 8, 2004 | 02:40 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
ok.....here's my take......(which seems to be repeatedly posted every 2-3 months...lol...but thats ok)
Upgrading the HU will give you better control of sound quality EQ tweaking, something the stock Clarion HU lacks...I think.
The stock BOSE amp is decent BUT remember, the stock Bose amp only drives the coupe's rear shelf 6x9" "subs" or the sedan's trunk sub. IT DOES NOT drive the front separates or the backseat side panel speakers, they are powered by the HU only!
The stock speakers suck and IMO are the truly limiting factor of the terrible or rather inadequate sound quality (saying terrible might offend people who think the stock sound quality is ok..again IMO) of the stock setup. SO......if you change the stock Clarion HU to a better aftermarket HU and you still have the poor stock speakers, your sound quality MIGHT not be as good as you expect it to be.
My advice would be to swap out your HU, KEEP the stock Bose amp and rear speakers, BUT CHANGE out your front components and you can either use the BOSE amp (with LOCs) or install a 2-channel amp to drive the the fronts. Unfortunately, there is no shortcut around the crappy stock speaker situation besides at the very least swapping out the front components.
Again, my opinion based on my personal upgrade project.....
hope this helps....
doc
Old Dec 8, 2004 | 03:28 PM
sebass04's Avatar
oh I forgot to mention.. I change my front speakers already with rockford 2004 PUNCH SERIES P162S 6 1/2" COMPONENTS.. So I guess no need to change the amp right? With the pioneer deh-860mp, that should be enough to run the speakers.. I'm also goin to install JL12W6V2 and a 500.1 amp for the sub.. hopefully this setup will be enough to satisfy me... Any other comments or advice on what else I need to do.. coz If i'm goin to install everything.. i don't want to have to go back and take my parts apart.. thanx..
Old Dec 8, 2004 | 03:37 PM
docron1's Avatar
make sure you have the Scorsche NNO3 wire harness and Nissan Antenna adapter for your aftermarket HU if you don't already have them......
The Pioneer HU should have enough power to drive the speakers adequately I think, but if you only do that and do not add a 2-channel amp, you might not utilize the full potential of your aftermarket speakers........
doc
Old Dec 8, 2004 | 03:43 PM
sebass04's Avatar
thanks for the help joepaniolo.. I appreciate it.. oh and I do have the wire harness and the antenna adapter already.. just waiting til xmas to install.. I'm also goin't to put the new slim ps2 for my video... but I'll just have to figure out where to put it..
Old Dec 8, 2004 | 04:17 PM
docron1's Avatar
since the new slim PS2 is top loading, I saw someone mount it in the lower glovebox.....
doc
Old Dec 8, 2004 | 04:59 PM
sebass04's Avatar
cool thanks
Old Dec 9, 2004 | 09:43 AM
tekknikal's Avatar
just a correction- the amp in bose equipped G35 coupes does power the front speakers. It does not just power the rear 6x9s.
Old Dec 9, 2004 | 02:00 PM
sebass04's Avatar
so pretty much the sedan's speakers are also powered by the bose amp.. so that means I don't really need to swap my amp and the deck will be enough to power the speakers...
Old Dec 9, 2004 | 02:57 PM
tekknikal's Avatar
I dont know about the sedan, im just going off of what i have in the service manual for my 04 coupe, pgs av-15 & av-16.
If I had to guess, i would guess that the sedan is similar in that the amp is driving more than 1/2 so-called subs.
Old Dec 9, 2004 | 09:29 PM
docron1's Avatar
Thanks for the correction....its been awhile since I messed with my Bose amp. Its collecting dust in a cardboard box in the back of one of my closets at home. I was trying to figure out a way to try and convert it to a planter for my orchids....lol
doc
Old Dec 10, 2004 | 12:04 PM
tekknikal's Avatar
doc
no problem just making sure everyone was clear on it. I myself am replacing my bose system. My amp is not working properly and I cannot easily get one under warranty.... so I'm installing a whole new system.
