Need some amp advice
Old Jul 28, 2011 | 02:51 PM
Kayzer Soze's Avatar
hi guys, was looking to install 2 Cadence 12inch subs with amp (using the stock bose systemn and head unit), was wondering based on specs, what kind of amp would be best (looking for something that would run under $150 on ebay new or used). you advice is much appreciated! here are the specs
http://www.cadencesound.com/products/UD124HFi.html
12” Single Voice Coil Subwoofer
Specifications:
• RMS Power: 350 Watts
• PEAK Power: 700 Watts
• Frequency Response: 25Hz – 2.5 kHz
• Structure Weight: 120oz
• Sound Pressure Level: 94dB @ 1w/1m
• Impedance: 4 Ohm
• Mounting Depth: 6.06”
Old Jul 28, 2011 | 03:10 PM
eggyhustles's Avatar
Couldn't find anything good under 150
http://cgi.ebay.com/ebaymotors/SOUND...ht_3902wt_1165
Old Jul 29, 2011 | 10:12 PM
thanks for the link, gave me an idea of what i should look for (mono,...). would this do the trick by chance?
http://cgi.ebay.com/CADENCE-FXA1500-1000-WATT-MONO-AMPLIFIER-CAR-AMP-/290592077235?pt=Car_Amplifiers&hash=item43a8a335b3#ht_5489wt_952
Old Jul 30, 2011 | 01:04 AM
No
Some of their amps are cool. That one won't do what it says.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
