How to test speed sense wire and location?
Old Sep 2, 2011 | 10:16 PM
JJSOLON's Avatar
Ok let me start off by letting everyone know that I have searched and I have read the other post on this same issue. I have had no luck finding it so far. I know everyone says its the White with green strip wire but it not working for me. Is there a way to test the wires? Maybe a multi meter? My car is a 2005 coupe and I hooked up an alarm. So I need to find this wire to work some of the features the alarm offers like auto locks ect. Any help would be great. Thanks
Old Sep 3, 2011 | 10:17 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
This white with green stripe wire attached to the back of the stereo is the speed sensor wire:
If that doesn't work, none of the speed sensor wires will, as they all put out the same signal.
Old Sep 3, 2011 | 10:21 AM
JJSOLON's Avatar
Yah thats the wire I'm hooked up to. Isn't the voltage supposed to decrease when your driving on that wire?
Old Sep 3, 2011 | 10:44 AM
No, the VSS signal is a pulsed signal that increases in speed as the vehicle speed increases.
Old Sep 7, 2011 | 12:06 AM
YOUNG1TRAN's Avatar
So what would happen if this plugged was to be cut off? Isn't this the plug where u hook them resistor to, to make the steering wheel control to work? Just curious be uase i want to tap into the vss wire for my dd nav. Will I encounter any problem if I did that?
Old Sep 7, 2011 | 12:08 AM
YOUNG1TRAN's Avatar
Btw y is the vss wire hook into the stereo. N I apologize for many questions. But all ur answer are greatly appreciated
Old Sep 7, 2011 | 07:18 PM
Factory units use it for speed sensitive volume.
Aftermarket units use it for that and/or tracking vehicle speed when GPS signal is interrupted.
Old Sep 7, 2011 | 08:57 PM
YOUNG1TRAN's Avatar
Oh that's great to hear man. Glad I can use that wire to connect my vss for my dd. Btw ur shopping list is awsome has everything hooked up just need my dd finisher to come in m finish wit my install. Then off to dealership for them to fix my immobilized g35.
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
vstypicals
Jul 20, 2015 10:55 PM
