How much rms does your coupe handle.
Old Sep 27, 2011 | 10:11 AM
KnowScott's Avatar
I think you will be able to get by on the stock Alt. It's a pretty beefy Alt as is.
If you want to do it right and not worry about it get a HO Alt.
Do the big 3 and use 0 gauge wire as well as get a yellow or red top optima battery.
Old Sep 27, 2011 | 01:08 PM
Nico Koutouzis's Avatar
I was going to do the big three and add a smaller kinetiks battery in the trunk to help. (keep stock battery up front). this will prolly be able to handle 1000 rms and some tv's and leds
Old Sep 27, 2011 | 01:22 PM
Thats what I said I can just turn down the gains leksikon for lower wattage use. Also the alternator keeps charging no matter what. If the car is on, it rotates the alternator wheel creating electricity in the copper wraps. It will still create the same amount of electricity if you have 2 or 1 batteries no matter what. Adding a second battery will only help on the charging side. It would help either way.
Old Sep 27, 2011 | 02:18 PM
KPierson_'s Avatar
I would suggest you do a little research before you pull the trigger.
The alternator has a voltage sense input (pin 4 on the alternator). When voltage is low it turns the alternator on causing the alternator to generate power. When voltage is sufficient it shuts off. Alternators do not operate at a 100% duty cycle.
Adding a second battery will most likely cause the alternator to operate at close to a 100% duty cycle, thus adding more strain to it, leading to a shorter life. Adding a second battery is a common misconception - it is typically only advised for car off listening (by using a battery isolator) or used in conjunction with a HO alternator.
Old Sep 27, 2011 | 07:15 PM
Ok then i'll just buy a beefy battery up front and it would help
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Th611
Oct 27, 2015 03:48 PM
Frostbite91
Aug 2, 2015 04:59 PM
