Seeking advice: Replacing bose amp and speakers with aftermarket amp and speakers
Old Oct 25, 2011 | 04:20 PM
cv5boi's Avatar
Post Seeking advice: Replacing bose amp and speakers with aftermarket amp and speakers
I have a 2004 G coupe with Bose. I replaced the Bose head unit with a Pioneer AVH-P3200DVD + PAC ROEM-NIS2 a couple months ago. I also installed a system (2) JL Audio 10w3v3 powered by a JL Audio 500/1v2. The install went smooth thanks to Wrathernaut and docron1. I was debating whether or not to remove the Bose amp/speakers and upgrade to an aftermarket 4 channel amp and speakers. Now I have finally decided to upgrade the crappy Bose, but I am in need of some help/tips. I am keeping the budget under $350 dollars. If I am missing anything please let me know. Thanks in advance
My main concerns are:
1. Do I keep the PAC ROEM-NIS2 or swap to Metra 70-7550 since I am removing the Bose system completely out?
2. So do I unplug the Bose harness and leave it unplugged?, discard of Bose amp, and tap speaker wires from the Bose harness to the new aftermarket amp? Do I have to tap anything else from the Bose harness to the aftermarket amp? Or do I actually have to run completely new wires?
I found this diagram on Cruthfield. Does it seem correct? Btw not using a capacitor
Parts list:
Kenwood Kac-8405 or Infinity Reference 475a 4-Channel Amplifier
6.5 Fronts Infinity reference 6030cs components
6.5 Rear Infinity reference 6032cf coaxial (Not going to use the OEM 6x9 Bose subs)
(4) 6.5 mdf spacers
(2) Distribution blocks one for power and the other for ground
(2) RCA cables one for front and the other for rear
4 gauge wire for power and ground
Old Oct 25, 2011 | 08:40 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Parts list:
(4) 6.5 mdf spacers
#1 - You can keep the ROEM.
#2 - Run new RCAs from the headunit to the amp. You can keep using the wiring from the trunk to the speakers that the factory system used.You can use the same amp power signal wire as well.
#3 - With a budget like that (even with a much larger one) forget about a 4-channel setup. 2-channel front soundstage is definitely the way to go.
Old Oct 25, 2011 | 08:54 PM
eggyhustles's Avatar
wrathernaut is right.
Ditch the cap, and put a big battery upfront. Battery along with proper sized wiring and distribution should be more than enough for you.
I'd also ditch the infinity stuff.
Old Oct 25, 2011 | 10:34 PM
cv5boi's Avatar
So its ok to leave the bose amp unplugged and speaker wires tap into the aftermarket amp correct? Any other good 6.5 components that dont cost arm and leg? Focal? Polk? Any good? How about good amps? Thanks for the tips!
Old Oct 25, 2011 | 10:44 PM
Budget
Without terms like sq and spl, what is the exact goal?
Old Oct 25, 2011 | 10:54 PM
cv5boi's Avatar
Just sq really just wanted to upgrade the crappy bose highs and mids.
Old Oct 25, 2011 | 11:01 PM
So its ok to leave the bose unplug and speaker wires tap into the aftermarket amp correct? Any other good 6.5 components that dont cost arm and leg? Focal? Polk? Any good? How about good amps? Thanks for the tips!
I unplugged my bose amp, tore it apart and danced upon the ashes.
Old Oct 25, 2011 | 11:22 PM
cv5boi's Avatar
AHAHAH! good one
Old Oct 26, 2011 | 08:31 PM
g35kid00's Avatar
im interested in this myself i just installed a sub in my car and the interiors sound shitty and the subs hit hard..... i just can't win!
what kind of amp/watts are you gonna run ?
Old Oct 29, 2011 | 02:50 AM
cv5boi's Avatar
http://www.ebay.com/itm/CL-61A-CDT-A...item1c15052c23
These any good? or the polk db6501 or mm6501?
Old Oct 29, 2011 | 09:26 AM
Even 50w per channel to two good speakers up front will be fairly good, but 250w/channel is as high as you should need to go.
mjfenix
Aug 17, 2017 05:49 AM
Frostbite91
Aug 12, 2015 05:16 PM
Frostbite91
Aug 2, 2015 04:59 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
