Rewiring Front Doors
Old Dec 21, 2011 | 05:23 PM
Micro's Avatar
Has anyone actually just taken the doors off and drilling new holes in them instead of drilling a hole through the molex to run new wires or is that just even more work?
Thanks
Old Dec 22, 2011 | 01:55 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
I don't think anybody who's done the wires through the molex has recommended anyone else do it. Just way too much work for a negligible gain at best.
Old Dec 22, 2011 | 02:04 AM
Micro's Avatar
So the stock wires are good enough to handle a 150 rms speaker?
After I get all my equipment together I'll take a look at it and if it's to much of a pain I'll just leave the stock wires on.
I actually seen pics of some that just drilled a hole, I think it was right under where the molex is located and put one of those rubber rings around the hole (not sure what they're called) that protect the wires and put a protective sleeve around the wires and it look pretty good. I'll try see if I can find the pics.
Old Dec 22, 2011 | 02:42 AM
Micro's Avatar
Here you go I found the pic. The car is actually a 350Z
Old Dec 22, 2011 | 08:59 AM
I've been running it like that for about two years now, 150w RMS per speaker, so yes.
Look how big the wires from the terminals on the speakers are to the coils. If your wiring to it is equal to or bigger than that, you're fine.
This is a $2,000 Focal 165 KRX3 150w RMS speaker:
500+w sub:
Last edited by Wrathernaut; Sep 5, 2012 at 06:08 PM. Reason: fixed broken image link
Old Dec 23, 2011 | 02:02 PM
BallerOnaBudget's Avatar
+1 for some good knowledge!
Old Dec 23, 2011 | 04:22 PM
And somebody's bound to say the length of the cable means you need thicker... for DC, yeah, but speaker signals are AC, so you're quite fine for the few feet the speaker signal has to go.
jsimonk
Dec 22, 2023 03:49 PM
tiguy99
Mar 1, 2016 11:42 AM
Karl_g335x
Aug 3, 2015 03:43 PM
will091195
Jul 27, 2015 09:19 PM
