g35 audio upgrade
g35 audio upgrade
I am about to buy a 2003 g35 auto, im wondering if anyone has had any issues with there interior or engine because of an audio upgrade. i plan on putting 2 12in sa12s on a 2000 watt amp, a c&d 540 battery, and 2 runs of 0 gauge welding cable and a high output alt. anyone with a big setup have any problems?
I just installed my sound system in yesterday,the problem is,how are yo going to fit the 0 gauge wire thr the firewall without drilling a new hole and "insulate" it?
And what are you gonna do for power?for example i only have a 600w with 2 cheap 12 and half volume my idle jumps.
third, where are you gonna hide the 0 gauge inside the car?
There's room for a couple 0 gauge wires along the bottom of the doors:
With the wire tucked under:
and just to make sure are you a coupe or a sedan?
edit,never mind you are a sedan,could you please upload a picture of your blue harness from the bose amp,if thats the way your connecting your setup,and not from the LOC unit.
Thanks
Otherwise yes your drawing a little bit more power than what the car is designed for
basically the idle jump,but i have not noticed any difference at higher RPM like light dimming or ecu cut out or any jerkyness.
Hope that helps.
