need help wiring avic z130bt
Old Jan 26, 2012 | 03:51 PM
bricks's Avatar
can some help me with wiring the pioneer avic z130bt im not sure how to connect the rca cables the the pioneer unit. im not sure what im doing wrong but for some reason i have NO SOUND ?
Old Jan 26, 2012 | 04:25 PM
Glex25's Avatar
Administrator
I believe you might have ordered the wrong interface harness and will need to purchase the correct one which doesn't come with the RCA Jacks.
The RCA interface harness is only if you are going to be using a external amplifier.
If you are not going to use a external amplifier then the harness will be all wires.
Old Jan 26, 2012 | 04:33 PM
Brew_haha's Avatar
www.avic411.com will help you out alot with any question you might have. I was able to upgrade my z110bt to a z130bt with the cracked software they have
Old Jan 26, 2012 | 11:50 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
This is like saying "my cookies suck, I put eggs in them what did I do wrong?"
We need to know a lot more to help.
Bose? Non-bose? if bose, did you keep the bose amp? Did you use the PAC ROEM-NIS2? Metra 70-7551? How did you connect your amp power-on signal wire? Did you replace your amp? If you replaced your amp, is it turning on?
Old Aug 23, 2020 | 01:18 PM
Warren Brown's Avatar
Infinity G35 coupe
Bose bypass
I have bose speakers in doors and replaced the amp and sub woofers. Yes i used the Metra 70-7551 harness but the idiot helping .e cut all my dash wires saying I didn't need the harness i have attached pictures to this nightmare
Hiw i have the trunk wired up
Old Aug 23, 2020 | 01:19 PM
Infinity G35 coupe
Bose bypass
How i have the trunk wired up
I don't think this is right
I tried to fix it best i could
Old Aug 24, 2020 | 03:20 AM
Scorpi0's Avatar
Holy crap!
Kingfanpaul@sta
May 19, 2010 01:55 PM
ghuynh
Apr 1, 2010 11:45 AM
OBG3506
Apr 8, 2008 11:48 AM
