NEED HELP ! Im about to run some serious power.
Old Feb 9, 2012 | 03:21 AM
Minki's Avatar
So i just ended up buying a 15" Sundown Nightshade with DC Audio Level 5 parts. Its a massive sub. Im either going to go with 2 US AMPS M2D2 or a single 2010 kicker zx2500.1 , whats a better choice of amps? Will i be ok with two yellow tops in the back?
it will be going in my 04 sedan
Attached Thumbnails NEED HELP ! Im about to run some serious power.-419633_278430362224471_100001725297835_695352_1038566882_n.jpg
Old Feb 9, 2012 | 04:02 AM
theONE719's Avatar
id say get better batterys than yellow tops, but cant speak for the amps, never used either. but beastly *** sub man!! **** looks incredible, wish i could have afforded some nightshades, i went with 2 sa's instead.
Old Feb 9, 2012 | 09:58 AM
eggyhustles's Avatar
go xs power for batts
between the amps, i'd go with the kicker.
I'd take a sundown amp over both, though.
Old Feb 9, 2012 | 12:26 PM
Minki's Avatar
I was actually running 4 sundown audio sa8s v1s not to long ago. But i ended up selling them. here was my setup
and i already have a kicker zx2500.1 i was getting a good deal on the 2 US AMPS from the guy i bought the sundown. He said both amps for $600. They are rated at 2000 rms EACH so it will be close to 8000 watts. Where as the kicker amp is 2500 watts rms
Attached Thumbnails NEED HELP ! Im about to run some serious power.-375951_229912390409602_100001725297835_581241_1256715893_n.jpg   NEED HELP ! Im about to run some serious power.-photo-7-.jpg   NEED HELP ! Im about to run some serious power.-311490_215928648474643_100001725297835_542371_1722834207_n.jpg
Old Feb 9, 2012 | 08:09 PM
guitarrocker98's Avatar
Kicker Amps are good. You should be fine running that. I have a hifonics one that is GREAT!!!!! Get a battery for your car aw well and use a 0 gauge kit. Anything less you could have a issue in the trunk. I had problems with speakers cutting out until I got a yellow top battery. Solved everything for me.
Old Feb 12, 2012 | 12:45 PM
blazeplacid's Avatar
You need to upgrade your alternator also.
Rhinos7777
Sep 6, 2015 05:36 PM
G35CO
Sep 4, 2015 09:27 AM
TheBay
Sep 3, 2015 03:27 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
