push eject???
Old Mar 8, 2012 | 08:33 PM
ibg's Avatar
ibg
push eject???
im trying to change cds on the cd player its a 04 sedan with premium package it has 6 cd changer and i press DISC and the screen says PUSH EJECt which i am over and over and nothing its not letting me insert a new cd does the cd not come out from the front stereo panel or something??
Old Mar 8, 2012 | 08:40 PM
herrschaft's Avatar
The CD's come out from the front but your disc changer is probably bad. Had to replace mine 3 years ago for the same reason.
Old Mar 8, 2012 | 08:50 PM
TunerMax's Avatar
G35
had to be done.
Are you sure it has a CD in it?
Old Mar 8, 2012 | 09:02 PM
ibg's Avatar
ibg
any way to check if it is good or not? besides just pressing the button
Old Mar 8, 2012 | 09:35 PM
Gold2006G's Avatar
try pushing, eject, the number of the cd that you want to eject, then push eject again...don't know if it will work or not...
Old Mar 8, 2012 | 11:26 PM
GAU-8's Avatar
Yah, I think you need to select the disc number you want removed as well.
Old Mar 9, 2012 | 03:08 AM
infamuz's Avatar
when you push eject does it sound like the cd player is jamming or cycling? yeah i read up on the forum that the cd player was going bad but as of last night i got my cd's to eject by opening the cd player "door" with my license then pushing eject. it managed to pop out all 6 cd's and returned it to normal.
Old Mar 20, 2013 | 10:16 AM
2005G35xSedan's Avatar
I'm having the same issue, over night I removed the negative to the battery, put it back on this morning which reset the cd player and then allowed for the eject to open but cd would come out I forced it out with another cd.
Once I got 2 cd's out it went back to its original state, of "push eject" and nothing happens.
Did anyone fix this yet? If so how?
Old Mar 20, 2013 | 01:08 PM
GR6RR's Avatar
slap the **** out of it. it should start to shuffle and eject your cds.
Old Mar 20, 2013 | 03:00 PM
I have been slapping the **** out of it and nothing happens, however that method has worked for me before.
My problem is the CD player won't even play any Cd's anymore and it sounds like the 2 Cd's that are left in there are stuck I hear movement but not much.
If I can't fix it I'm just going to install an iPod hookup. Not worth the repair.
However I'd rather be able to fix it myself so if anyone else has this same issue of the Bose HU stuck in saying "push eject" and nothing happens, please share.
Old Apr 4, 2013 | 06:04 PM
epenbecks's Avatar
same here. i just got my G35 '04 6MT. and try to insert cd and doesn't work. the screen says PUSH EJECT. any suggestion?
Old Apr 4, 2013 | 07:22 PM
GR6RR's Avatar
^ just a question to you... have you tried slapping it? palm and fingers open to the face after you push eject and it starts clicking? It has worked for me as had worked for 2005G35xSedan too. well, before anyways..
Old Apr 4, 2013 | 07:29 PM
Yeah my solution to this problem was investing in an iPod hookup and forget about the CD player all together.
However I do get an annoying noise from the CD player every time I turn the car on.
Sounds like its jammed.
Hope that helps.
Old Apr 4, 2013 | 08:10 PM
dofu's Avatar
20 Year Member
You can get your cd player refurbished for about $50, just gotta look around.
Old Apr 5, 2013 | 10:53 AM
broke_as_ajoke's Avatar
I had the same problem.. i beat the cd player on the side and nothing happen, i tried the battery and nothing happen, tried another cd to get them out and nothing happen.. to make a long story short.. I REMOVED THE JUNK And bought a new after market head unit
