Subwoofer problems: Works if I hit it.
Old Mar 13, 2012 | 09:41 PM
DaAliGsdn's Avatar
Hey all. I just got my 03 Sedan. It's got 93k miles on but is in immaculate condition. However, the subwoofer won't work unless I open the trunk and physically the sub - which requires taking off the trunk liner.
Is it a loose connection on the sub or does it have something to do with the amp ? Thanks.
Old Mar 14, 2012 | 01:35 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Could be something just loose.
I'd disconnect all the harnesses from it, make sure the wires are shoved in tight, and re-connect them. If that doesn't work, get somebody handy with a multimeter to test it when it isn't working to try and find where the fault lies.
Old Mar 14, 2012 | 01:49 AM
Eric@TCGMiami's Avatar
there is a small box under the sub, it's the amp for the sub (hidden under the plastic) where the speaker goes ... somehow it goes bad and sometimes tapping it fixes the problem.....I've had that issue...... My solution:
Purchased a 10inch W6, got a converter, also added an amplifier, and viola no more issues !!!!
Old Mar 14, 2012 | 06:20 AM
Yes, the JL 10w6 is definitely a solution
Old Mar 14, 2012 | 10:46 AM
thx,
just upgraded to a 10w7.... also your thread for the 2Din is great I am going by it like it's the bible.
Old Mar 14, 2012 | 06:29 PM
eggyhustles's Avatar
Coil rub is the issue.
rezendvous420
May 31, 2020 01:26 PM
kinetek
Aug 3, 2015 04:25 PM
newg37
Jul 26, 2015 09:32 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
EasySausage
Jul 14, 2015 11:17 PM
