To Dynamat or not?!
To Dynamat or not?!
Hey all, looking for input...
I am about to upgrade my audio system (new HU, amp, sub, cap, speakers) and I was looking for advice on using the Dynamat (or other product). I have done lots of systems in lots of cars, but I have never done used this type of thing.
Should I go to through the work and cost of this step? What is good for? What would I gain? Where should I do it?
Any input or advice would be great!
Thanks!
Thanks!
Dynamat is great! If you have the funds and more importantly the time to apply it or get it done, then go for it! It will help reduce any unwanted vibes that may be a direct result of a high power sound system, as well as if you plan on adding some major bass. It also helps reduce road noise and keeps the inside of your cabin quiter, which is a plus for any sound system, stock or not. Most high end cars these days even some mid-class vehicles are now coming with a dynamat like coating and or sheet in the doors, pillars and body work, to further keep road, drivetrain and engine noises to a minimum. Once again, if you have the resources and the time to do it, its always a plus! If you dont want to go to crazy, only apply it to some of the more critical areas of your car like the trunk, the lid, the doors, behind and underneath your dash, and don't forget your licence plates (as they love to rattle - and Dynamat even makes special cut small pieces exactly for that). All in all, you cant go wrong it!
yea sound deadening materials help. Dynamat makes good stuff but they are very expensive. I think its over 120 for 36 sq feet. You can get a lot more from elemental designs with edead which is similar to dynamat. I dont know if edead is as good as dynamt or not but i doubt that you would be able to tell a difference, I think ed sells edead for 1 buck a sq foot. if you do your whole car, I would recommend at least 70 sq feet. good luck
yes...do it.
does it help? it's a question you have to answer yourself. i think there is a solid theory behind using sound deadening material, especially inside a car.
cheapest place is on Ebay. $120 shipped for a bulk pack. one pack allowed me to do the two doors, both rear qtr panels, underneath the backseat and under the trunk.
i bought another pack to do the trunk and eventually the wheel well (inside the car) and underneath the carpet.
IT IS A LOT OF HARD WORK!!!
a heat gun as well as a rubber roller will help. sharp cutting utensil (razor) and bandaids.
here's some pics...
here's some pics...
caelric
Apr 28, 2005 06:04 PM
cryhavok
May 20, 2004 05:06 PM
