Amp problem
Old Mar 25, 2012 | 03:54 PM
007JD's Avatar
Amp problem
I have a 04 sedan
I did the " add a sub to your stock Bose system"
And I recently got a kicker am zx750.1 with kicker 2 12" cvr
It has a 4 gauge wire
The problem I'm having
Is that it flickers to protection mode
And the bass **** doesn't work n I know the bass *** isn't broken
Any one can help me. Thanks
Old Mar 25, 2012 | 03:59 PM
g35pillow's Avatar
U check the fuse on the amp?
Old Mar 25, 2012 | 05:21 PM
007JD's Avatar
All fuses working
Old Mar 26, 2012 | 12:57 AM
Top Teke's Avatar
If it's flickering it sounds like something might just be shorting out - I'd start by checking all your wiring. Power, ground, speaker wire, and remote for any exposed area that could be touching metal somewhere. It could be that the vibrations from driving are making something touch. Bass **** might be unrelated.
Old Mar 26, 2012 | 01:05 AM
007JD's Avatar
so i recheck the wires n called a frin of mine . n he said chck the ohm wiring
since it was dual 2voice ohm . i had to wire it a different way. . i wired both positive 2gthe n both negative 2gtha
and so far it doesnt flicker into protection mode only if i bass boost half way and the same with the gain
but the thing is n ow that the bass **** doesnt work..
still no clue
Old Mar 26, 2012 | 01:07 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
If it's always cutting out and the protect light on, your sub is possibly too low of ohms for the amp to support. How are your 2 12's wired up? If you're in parallel (1 ohm load) then it's almost certainly too low for the amp.
Old Mar 27, 2012 | 08:34 AM
007JD's Avatar
i wired it 2 wires .. 1 wire just for the positive n 1 wire just for the negative . twisted at the end 2tha .
and into amp
i had it wired differently and it was flickering n wat not when i tryed putting the gain n bass boost up
after i wired howed i mention ^ it doenst flicker but // my bass *** isnt working now.
i ahve 2 bass *** n i know both work..
wat do u think
Old Mar 27, 2012 | 09:35 AM
In English please?
Pictures might help too.
Old Mar 27, 2012 | 10:52 AM
blazeplacid's Avatar
try this
run one sub on your next drive.
if everything works fine you need to check the wiring on the subs
later, try the other sub alone and see what happens.
make sure both subs are dual 2 ohm or dual 4 ohm. If they are different that can cause some wiring issues
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Ohsixgee35
Sep 16, 2015 04:33 AM
mattdg35
Sep 14, 2015 11:28 AM
Mhacker
Sep 12, 2015 07:35 PM
Jnm07
Sep 5, 2015 01:16 AM
