Does 2003 Infiniti G35 Coupe have a Power Antenna?
Old Apr 9, 2012 | 09:16 AM
cninham's Avatar
Question Does 2003 Infiniti G35 Coupe have a Power Antenna?
I have a 2003 Infiniti G35 Coupe. I have installed a new Pioneer AVH-P3400BH radio in the G35. I used the PAC ROEM-NIS2 (OEM-1) for the harness interface (conversion) between the new Pioneer HU and the vehicle's sound harness.
Here is my question: The PAC ROEM-NIS2 harness has a blue wire on the radio side which should be connected to the Power Antenna. Does the G35 Coupe have a power antenna? I know physically there is no power antenna. But is there some electronic component or "antenna signal amplifier" that I need to connect to the Pioneer head unit's Blue/White remote control (system control relay) antenna?
Thank you,
Cameron
Old Apr 10, 2012 | 12:54 PM
blazeplacid's Avatar
yes, connect the antenna wire
it should be located in the wiring harness that is coming from the factory wiring.
Old Apr 10, 2012 | 11:42 PM
Top Teke's Avatar
If you don't connect it you will have very poor FM reception.
Old Apr 11, 2012 | 12:20 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
There's no power antenna, just the antenna amplifier.
If your headunit puts out enough power, it'll power the amp, otherwise, you're better off connecting the "power antenna" part of the vehicle side wiring harness to a full-power (not just power-on *signal*) wire, like the red power wire going to the radio, or the cigarette lighter's +12v wire.
Old Apr 17, 2012 | 05:31 PM
cninham's Avatar
I have installed a Pioneer AVH-P3400BH radio -- do you happen to know if it outputs enough power for the power antenna & amp...? Is there some spec where I can find this value? What is a good value to have?
According to the specifications in the radio manual:
Preout maximum output level = 2.0V
Does this help?
Thank you, Cameron
Old Apr 17, 2012 | 07:41 PM
Top Teke's Avatar
The 2v that you're referring to is what the preamp outputs give (from your RCA outs). If you are concerned just set it up to a 12v constant source like the cigarette lighter like Wrathernaut mentioned.
Old Apr 18, 2012 | 12:49 AM
Does this help?
Thank you, Cameron
It's safe to assume that NO radio outputs enough, since all of the manufacturers have it set up to be a 12v *signal* not a 12v power source.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
ClwMike
Jul 23, 2015 12:55 PM
driftsucky
Jul 15, 2015 12:38 PM
