Heating problems after DD install
Old Apr 12, 2012 | 01:00 AM
Micro's Avatar
Just got my car back today. I had a whole new system put in.
I'm having heating problems and have seen a few threads about how I might be able to fix it.
61 degrees + is completely hot air.
I read that it could be the in cabin sensor. I'm having a problem trying to find the location of it.
I see that tiny rectangle vent on the lower right side of the steering wheel. Not 100% sure if that's it or not. If that's it I can seem to pop it out and see if the sensor is connected. I tried to use a screw driver to pop it out but it seems like it's not suppose to pop out. All I'm doing is scratching it up.
I have an 06 coupe in case it's located in a different spot then older years.
I'm going back to the installer tomorrow so he can take a look at it. But I figure if I would look on here and see if I can figure it out myself and save the trip.
If I could just find this thing I could probably fix it myself.
Thanks
Old Apr 12, 2012 | 01:30 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
The square doesn't pop out, you just reach behind it.
Old Apr 12, 2012 | 03:35 AM
Micro's Avatar
I'm going to have to take the plastic part off to be able to reach it because it plastic runs almost to my pedals. I'll take a shot at it tomorrow when I get up.
That's the only problem I'm having, everything else work with the controls.
Thanks Wrath
Old Apr 12, 2012 | 04:18 PM
Micro's Avatar
Ok, I took the bottom apart and found this thing hanging down. Is this what I'm suppose to hook back up. I just need to find where it goes.
Here's picture I took. For some reason is won't upload my picture so I had to use imageshack.
http://img98.imageshack.us/img98/5716/img0099ol.jpg
Old Apr 12, 2012 | 04:28 PM
Micro's Avatar
Here's a picture of the hose I think other members were talking about, not sure. Is this hose suppose to be connected to somewhere also. Everything is so tight under there I can't see where to hook anything back up.
http://img687.imageshack.us/img687/7857/img0101ik.jpg
Old Apr 12, 2012 | 06:19 PM
Micro's Avatar
I can see where the tube is coming from just can't find where to connect it. So much stuff under there.
Old Apr 13, 2012 | 03:01 AM
Sorry, I can't see imgshack from here, it's blocked. Somebody else care to assist?
Old Apr 13, 2012 | 01:09 PM
Micro's Avatar
I figured it out. The sensor is completely gone, looks like it was broken off. No wonder I couldn't figure out where that tube and wire plugged into. Going back to the shop today.
Old Apr 13, 2012 | 01:18 PM
Top Teke's Avatar
Try this Wrathernaut.
Old Apr 13, 2012 | 04:13 PM
Micro's Avatar
Thanks. The installer is ordering me another sensor.
Old Apr 13, 2012 | 05:28 PM
Yeah, photobucket too.
Still, can't complain too much, I'm in freaking afghanistan.
Also, that panel should never have required removal in an 05+, your installer should watch my videos :P
chinee
Jun 10, 2024 07:48 PM
saskicker32
Aug 11, 2015 02:12 PM
Smittie20
Aug 9, 2015 04:29 PM
Phenomenon9
Aug 9, 2015 01:34 AM
attarday
Jul 15, 2015 04:03 PM
