Sound like an Audio AC Finisher issue?
Old May 17, 2012 | 09:32 AM
blong5150's Avatar
03 G35 Coupe:
I posted a while back about not having heat. Between myself and 2 shops it has never been fixed. I just got it back from the 2nd shop and they said that they did some sort of diagnostic and I seem to have an Audio AC Finisher issue. However, they still suggested that I let the dealer make the final call on it.
Here are the symptoms:
  • Obviously No Heat
  • I would think that when you turn up the temperature to where the heat should kick on, the AC button would no longer be lit. It always stays on but can be turned off manually.
  • The left channel in my stereo comes and goes (this just started). I thought it was a loose wire because it sometimes comes on when I hit a bump.
Old May 17, 2012 | 05:37 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The light comes on because it keeps the a/c compressor on as a dehumidifier, which aids the defrost and kicking out the moist, damp air.
If the a/c controls appear to work (changes the temp on the display) then it's not the finisher. The temp sensor could have been disconnected, in which case, this post: https://g35driver.com/forums/audio-v...n-install.html will help.
However, my suspicion is that it's a bubble in the cooling system. Check the other non-audio-visual forums for stuff on that subject.
Old May 18, 2012 | 09:40 AM
blong5150's Avatar
I went for months thinking it was a bubble in the cooling system. It's definitely not. I'll check the temp sensor.
derres
Aug 28, 2015 03:27 PM
Phenomenon9
Aug 9, 2015 01:34 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
kd03g99
Jul 30, 2015 11:24 AM
