Point me to a LOC that converts Diff. Balanced to RCA
Old Nov 8, 2012 | 03:06 PM
jhatfie4's Avatar
I am wanting to do some audio upgrades on my 05 G35 coupe w/ Bose HU.
I am going to keep the HU for now as the trim kit is so expensive. I'm just going to use a Bose wiring harness to RCA then RCA to AUX since that is the only input I usually use anyways. This will mean I can hook up my phone to my headunit for a cost of about $20 or less.
I am going to replace the Bose amp with:
http://www.amazon.com/dp/B007S58R6E/...9RFGH3FAEAY054
Will this amp accept the Differential Balanced inputs? Will it accept RCA's that have been converted from Differential Balanced inputs? I don't see how a LOC is different from splicing the wires to an RCA.... Or how some LOCS work for this and some don't..
I'm very confused by it and have read A LOT of articles.
Thanks in advance!
http://www.amazon.com/Soundstream-RU...ndstream+600.4
Old Nov 8, 2012 | 04:47 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
No, soundstream don't take balanced signals. JL amps do.
LOCs convert the audio from a speaker-level signal to a lower-level signal, not just converting the format of the connectors.
Old Nov 8, 2012 | 04:56 PM
jhatfie4's Avatar
So even if I converted them, the soundstream will sound like crap because of the diff balanced BS...
So how about an amp that accepts diff balanced? i'm looking now at the Kicker zx650.4 with two front channels powering Image Dynamics components at 4 ohms, and the two rear channels run to each of my Alpine Type R's 2 ohm voice coils... That'll give the components 120 RMS and the sub 340 RMS.. not running the rear speakers
Old Nov 8, 2012 | 06:08 PM
That amp should work well, just run the pre-amp signal from the headunit into the RCA inputs on the amp.
Old Nov 9, 2012 | 10:37 AM
jhatfie4's Avatar
awesome, thanks for the info
Old Nov 10, 2012 | 04:51 PM
gl35's Avatar
I think a MTX RE Q5 should work (or another similar MTX RE product in the same line). I had the same problem.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
vamarris
Sep 26, 2015 12:56 PM
