Help me decide on components!!
These
http://www.sonicelectronix.com/item_...CTX-6.5cs.html
but they're back ordered and the jbl's are better
I hope you plan to amp them
These
yes, i plan to run them through an amp, thanks for your input!
Any other opinions? just trying to see my best options here!
Not to thread jack but I got my Pioneer AVH 8400 headunit put in a couple weeks ago, Im loving it but now Im ready to upgrade my speakers (and add a subwoofer)
is there good value to be found in this package:
http://www.sonicelectronix.com/item_...Dampening.html
Comes with JBL speakers for front and back
800 watt 4 channel NVX amp
NVX Sound Deadening
I like it because its an all it one solution to my speaker problems and I can quickly move to figuring out what I want to do with my sub stage. But is this package deal a good value at $590?
NVX Sound Deadening
NVX Sound Deadening
NVX Sound Deadening
Would be a good deal if it were one pair and cheaper
Piece it together
http://www.sonicelectronix.com/item_...BL-MS-62C.html
http://www.sonicelectronix.com/item_...-JAD800.4.html
^ on the CTX6.5 this is the depth and they fit in the front with no problem; however, I'm not sure about the depth of the space in the rear, but one would assume that it must be about the same since the 6.5 is the same as the front. The front and rear speaker is a 6.5 inch mid speaker.
Top-Mount Depth 2-3/4" ≈ 2.75
Bottom-Mount Depth 2-7/8" ≈ 2.88
Cutout Dimensions 5-5/8" x 5-5/8"
So lets say if the speaker is 3 inches deep You might be running into trouble. I think you will need some spacers if they are more then 3 inches in depth.
I'm not 100% sure.
I'm not 100% sure.
