Kenwood DNX1940 doesnt start. HELP!
Old Mar 17, 2013 | 11:36 PM
DjGenuine's Avatar
Help....
2007 G35 Coupe Automatic
I was installing a rear view camera, i was connecting the red power wire from the camera to rear of the unit and i accidently touched the black wire from the unit. It created a spark and the unit turned off. I turned the car on and tested the unit and nothing...now it doesnt turn on. I also noticed my speedometer lights are off too. All other lights are fine. Also my memory driver seat doesnt work either.
I looked @ some fuses...but dont see any burned. My dimmer is all the way up.
Please help!...is my unit done? Is their a fuse i should looking @? Is there a wire to replace?
Any help or ideas would be appreciated!
Old Mar 17, 2013 | 11:46 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
I'll take this time to remind people to disconnect the battery when doing electrical... all it takes is a slight tap and your fuse is blown. Disconnecting the battery prevents this.
Anyway, yeah, you blew a fuse.
There's two fuse boxes in the battery compartment and one in the driver's kickpanel, find and replace the burnt-out one(s) in there.
Old Mar 18, 2013 | 12:00 AM
DjGenuine's Avatar
Thanks for the heads ups...
I checked the RADIO fuse and doesnt look blown.
I will replace it tomorrow anyways and see if it fixes it...fingers crossed.
Old Mar 18, 2013 | 12:05 AM
Looks like you got in before the edit - it could be another fuse, you're going to just have to pull and check them all.
Old Mar 19, 2013 | 10:49 PM
DjGenuine's Avatar
It was the MIRROR fuse. Back to normal. Thanks for the help Wrathernaut!
magnetism80
Feb 1, 2019 10:00 AM
Frankieg35
Oct 7, 2015 10:22 AM
1Typhoon
Sep 25, 2015 08:45 PM
Rhinos7777
Sep 6, 2015 05:36 PM
D1dphresh
Aug 7, 2015 06:10 PM
