Sound deadening the coupe
#32
Got me. I hope to hear from Naut today before I get off work. My Rat Trap showed and looking to do the trunk today, but would like to know of the spray foam so I can pick it up after work before I work on the trunk.
#34
SergeantRed (05-16-2013)
#35
#36
#37
The doors are a lot easier! Just make sure that when you put them back together the ball on the end of the cable for the door handle is placed back in position correctly otherwise you'll put it all back together, like I did, and realize you can't get out of your car.
Thanks Naut. I found what I was looking for yesterday. The flexible foam for windows and doors. It was called "The Good Stuff" and it was $6 for a can.
Another question. I was told that Fat Mat doesn't smell, but this morning upon entering the car the cabin smelled of Tar. I'm assuming that's just because it was freshly installed. Right now my car is parked at work with the windows down and the trunk open. Will this smell go away?
#38
Oh ya, it goes away in about 2-4 weeks max! I have some non-standard stuff in my car and it wreaked for the first week but even that went away. With the temperatures in the 80s and 90s it's going to heat it up and the smell will be strong for a while. Windows down will help it to escape and not build up as much. All depends on your nose too. I can't smell **** so for me I had to be right up next to it.
#40
#42
I just spoke to a very nice lady at Fat Mat and here is what she said.
The reason it smells is because it came hot off the press, into a box, and right in my trunk without any "air out" time. Which makes sense because I literally brought the sealed box down to my car and put it right in my trunk. She said the smell will go away within 3-4 days, but in the meantime get an odor absorber if you can't stand it. I may pick up a few small boxes of baking soda to help with this.
A little bit about the product straight from the rep...
It's not strictly asphalt based, but an "alternative." So there is asphalt in there, but not like the old ones used to be. It's an asphalt/rubber alternative. She said the Rattle Trap (80) is very similar in performance than the thinner butyl products because it's just as dense as the butyl rubber (granted 1/4 thicker)!
A little about heating and sliding around...
She said the main difference between the Rattle Trap and the Mega Mat is about 50 degrees. The Rattle Trap is rated around 250-260 degrees. So in an event of a fire, the Mega Mat will be a better choice for that 50* rise. I also brought up how people post about asphalt based products heating up and sliding around. She said to watch out for when those posts were made (I verified this and does seem to be true) because the products have been revamped since the earlier versions to resist higher heat.
She also said I'm a bad *** mother****er! Which I replied I duly appreciate that!
#43
I never had any smell at all with the CLD tiles from SDS.
No, you don't need to velcro the entire thing. Just enough to hold the weight really.
Good Stuff brand is what I used in mine too. Just make sure you're not injecting it anywhere that there are factory wires or access required... goes in easy, major PITA to remove.
#44
Just FYI there is a brand called B-Quiet which is every bit as good as Dynamat but about 1/20 the price. I have used it on my last three vehicles and it's excellent (and is butyl-based so does not smell when warm).
There is a B-Quiet distributor in Alberta who lists on Ebay. Not sure if there is a US distributor but even with shipping to the US it would be cheaper than Dynamat of FatMat.
Dynamat is a huge rip-off. You're paying large $$$ for the name alone, just like Monster Cable.
#45
