'06 Sedan keyless entry intermittent???
Old Jun 3, 2013 | 08:12 AM
350Zed's Avatar
Exclamation '06 Sedan keyless entry intermittent???
My keyless entry (not Intelligent Key) remotes suddenly started working only intermittently--the keyless door lock/unlock will work for a short period of time, then stop working, then start again under no particular conditions.
Here's what I have tried to no effect...
1. Try different remotes (I have 4 that all worked before)
2. Replace remote batteries
3. Disconnect car battery for 30 min
4. Reprogramed remotes (the car doesn't even detect any of them)
5. Visually-checked the control module under the dash, right side of the glove box (no loose connections of evidence of water intrusion)
I'm taking it to my mechanic later today, but I'm hoping someone can point me to some possible failure areas.
Old Jun 3, 2013 | 07:08 PM
350Zed's Avatar
So after further testing, the remotes always work, it's their RANGE that's variable. Sometimes they only work while I'm sitting in the car, and sometimes they have a range that's just outside the car.
Could a receiver antenna have become disconnected? Where would I start to look?
HELP!
Old Jun 3, 2013 | 08:23 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Either the receiver's malfunctioning, or you've got something generating interference.
snic09
Nov 8, 2017 01:46 PM
wuppiedog
Aug 7, 2015 11:16 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
gabe3d
Audio/Video/Electronics
Jul 19, 2015 05:43 PM
