'05 Sound upgrade...?
Old Nov 16, 2013 | 09:41 AM
dundermifflin99's Avatar
What might I be looking at for a overall sound upgrade on stock Bose system..?
speakers
amp
sub...
Have about $500, which i know is not a whole lot, but the sound is not very impressive at stock level..
thank you
Old Nov 16, 2013 | 12:50 PM
G_zus's Avatar
I'm not an audio buff by any means but I'm sure you could get a nice little upgrade all around for $500...not including labor. Would you do the work yourself?
thank you
Am I the only one who thinks the stock Bose system is pretty solid??
Old Nov 16, 2013 | 01:31 PM
jookyshank's Avatar
I haz hugz to givez
The stock Bose was decent if you don't crank it to much but windows down mountain runs were its downfall for me ... Check the marketplace for some great deals , and honestly internet prices on audio equipment are very nice these days I built an entire Pioneer system brand new for under $900 I'm sure you can find a good system for your budget
Old Nov 16, 2013 | 03:47 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The stock non-bose is better than the bose.
Anyway, start with this post that is at the top of the forum:
https://g35driver.com/forums/audio-v...-stock-hu.html
If you're up to replacing the headunit as well, check this one, also at the top of the forum (seeing a pattern?):
https://g35driver.com/forums/audio-v...urce-list.html
And if your pockets run deep, here's yet another post from the top of the forum you'll want to check:
https://g35driver.com/forums/audio-v...o-systems.html
Old Nov 17, 2013 | 07:30 PM
eggyhustles's Avatar
With 500, I'd probably sound deaden the doors, trunk, and rear deck. Adequate sound deadening is usually the weakest link in these setups. It's amazing how just sound deadening(properly) a factory system can improve the sound quality. The processing in the bose eq/amp is also a weak link.
Old Nov 18, 2013 | 04:56 PM
I'd put sound deadening second behind putting some properly amplified components in the front doors in terms of sound quality increase in our cars. If you don't have the bose amplifier, it'd probably come first in my upgrade order, simply because it lays a foundation for hearing everything better, ESPECIALLY when the car is in motion.
Remember, if you can reduce the noise floor, you're effectively increasing the perceived volume of whatever speakers/subwoofers are in the car. Adding decibels and sound quality up top costs more and more money the louder/clearer you want to go, but removing decibels of noise at the bottom has the same overall effect on how you hear your music (and is safer on your ears), it carries over to any future upgrades, and is usually cheaper to remove 6 decibels of noise (or more) than it is to increase the volume of the speakers/subs 6 decibels.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
