Help Please with Nav Unit Clips
I'm replacing my Bose Unit with a rebuild. Have all the clips removed but am not sure how to remove the two clips in the picture. Any help would be greatly appreciated. I'm always afraid of breaking the plastic clips. Thanks in advance!!!
Just push in the lock tabs circled. Use a small flathead screwdriver if you have one, and once the tab is pushed in, twist the screwdriver to push the harnesses apart enough that they can be simply pulled apart. If you don't have a small flathead screwdriver, push the tab in with anything the right size, then use any flathead screwdriver to push the halves apart. Once the lock tab isn't locking, they come apart easily.
Thanks Wrathernaut...I finally figured it out myself. I'm always concerned about being too rough and breaking something. I have a tendency to get frustrated and then start breaking things. I'm going to be installing a USASPEC model PA15-NIS. So you may hear from me again. I would like to commend you for the amount of effort you put into helping forum members. This is what forums should be about.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
FS[NorWest]: 04 OEM Faceplate and CD/Tape Unit
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
