radio stations weak sound, cd sounds normal ??
Old Jun 9, 2014 | 05:13 PM
cashedg35's Avatar
so my fm stations are turned all the way up to 31 and all you can hear is a whisper, but when i turn to CD, its loud and i have to turn it back down to 15. . .. i have already tried replacing the antenna amp but its still the same. what the ?????
Old Jun 9, 2014 | 07:31 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Aftermarket or stock radio?
Old Jun 10, 2014 | 11:41 AM
cashedg35's Avatar
stock radio. i wouldnt think that the factory radio would have an internal amp for FM and then CD. its just strange that i cant get any sound from FM stations but the CD plays as loud as it will go just fine. thats why i was leaning toward the antenna amp, but i already swapped with another and still nothing.
Old Jun 11, 2014 | 12:17 PM
Was the antenna amp you replaced it with a known good antenna amp, or a unknown used one? What about AM? Did you accidentally scratch and break the antenna wires on interior of the rear window, possibly through the removal of tint? Did the connector to the rear window antenna get unplugged?
Get a multimeter and check for power at the antenna amp. I'll assume you haven't removed the stock radio, so the chances of the antenna plug coming disconnected are virtually zero... If the antenna amp is getting power, your options come down more or less to pulling the radio and trying an external antenna or wired FM modulator plugged in to see if it's still not getting signal
Old Jun 11, 2014 | 06:16 PM
cashedg35's Avatar
wires are all good even at the rear window. the new amp was removed from a salvage car with low miles, jst seems the chances of it being bad as well are small. the radio station comes through clear, just isnt loud. if the car isnt running and not much outside noise i can hear the staions coming through clear, but its like the volume wont come up above a whisper. this is nuts. I would immediately think it was a bad internal speaker amp if it wasn't perfectly normal when i am playing cd's. . . . .
chinee
Jun 10, 2024 07:48 PM
TWASkyliner
Feb 8, 2020 08:00 PM
ScraggleRock
Aug 11, 2015 10:16 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
kd03g99
Jul 30, 2015 11:24 AM
