2003 g35 sedan own sub does not work
Old May 8, 2015 | 05:43 PM
s13envy's Avatar
Ok so I probably should have tried some troubleshooting first but I went ahead a bought a used OEM sub and amp for my car thinking that one of them had to be the issue. But I am still unable to get any sound from the OEM sub.
I have replaced the oem radio with a newer pioneer unit. The sub didn't work before swapping this out either. What am I missing? I've checked the radio fuses under the hood and under the dash and still nothing. The everything still works even if I pull the radio fuse out under the dash. What exactly are the fuses for? Any pointers would be appreciated
Old May 8, 2015 | 05:57 PM
s13envy's Avatar
Well after further inspection, I got ahead of myself and bought the wrong sub. I bought one for an 05-06 g35 sedan. This one only has 2 wires, mine has 5 wires. I'm assuming my oem is dvc and the 05-06 isnt.
Last edited by Wrathernaut; May 9, 2015 at 12:37 AM. Reason: Do not solicit sales in the discussion forums.
Old May 9, 2015 | 12:37 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
No, nothing about DVC - The 2003 sub has its own amplifier as part of the sub, so your newer subwoofer won't work off the line input signal that's going to it. You'll have to get a small (about 25-50w) amplifier to use the 05 subwoofer, or, even better, get a real subwoofer, box and amp instead of trying to run the shallow not-quite-8-inch bose POS.
Old May 9, 2015 | 12:41 AM
s13envy's Avatar
Hmmm i didn't know it had its own amP. Guess that explains the extra wires. I was under the impression that the amp under the back dash powered the sub.
One day I will put in an actual sub. I'd just like to get everything working on this car. It's got almost 300k miles and I'd still in really good condition.
Old May 9, 2015 | 03:46 AM
Hotdawwgman's Avatar
Whoa... 300k and you are worried about a sub? To each his own...
Old May 9, 2015 | 03:54 AM
s13envy's Avatar
What should I worry about instead? like I said, the car is in great shape.
Old May 9, 2015 | 12:14 PM
I, for one, am happy that a failing sub is top of the priorities list for our cars at 300k. I'm only at about 110k on my 05.
Old May 9, 2015 | 02:30 PM
s13envy's Avatar
Agreed. My car has very little rust. Just a few spots from rock chips on the hoof and such. had to put in a different engine due to failing head gaskets though. I'm just trying to keep everything working in the car.
Hasanbaloch
Feb 29, 2024 08:45 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Tom_P
Jul 24, 2015 04:05 PM
Chattzx
Jul 17, 2015 11:23 AM
