Anyone know where the stock antenna is?
Old 02-22-2005, 11:37 AM
Sundeviljay's Avatar
I got my stereo installed yesterday and now my radio reception is terrible. Does anyone know the location of the antenna so I can see what's wrong?
Old 02-22-2005, 12:18 PM
GRider35c's Avatar
yeah i think theyre along side the top of both sides of the car, above the windows...
Old 02-22-2005, 12:25 PM
I have done a search and can't find exactly where they are. Does anyone know how to get to the antennas? DIY?
Old 02-22-2005, 12:29 PM
pathfinder36's Avatar
I have the same problem. We stipped the car down and checked the antennas per the Service Manual. We couldn't find a reason for the issue. I'm almost thinking that the amps and\or the power wires are causing interference in the stock antenna.
Old 02-22-2005, 12:34 PM
No Solution?
Old 02-22-2005, 01:01 PM
s2kmugen's Avatar
its in the defrost/rear window
Old 02-22-2005, 01:36 PM
xswl0931's Avatar
Note that it is a powered antenna. Did you hook up the signal indicator for the powered antenna?
Old 02-22-2005, 01:38 PM
gspotter's Avatar
What kind of amps do you have? Class D amps (often used to drive subs) often screw up radio reception.
Old 02-22-2005, 01:47 PM
docron1's Avatar
Location: Centerburg, Ohio (the geographical center of the Buckeye State)
Did you splice/connect the powered antenna wire on your wire harnesses when you swapped your HU? Did you hook up your antenna adapter to the stock antenna plug and then plug it into your HU?
These 2 things are the usual culprits to poor radio reception......it shouldn't be your stock antenna that's the problem...
doc
Old 02-22-2005, 01:50 PM
I installed a JL 500 mono amp. I did not change out the head unit though...
Old 02-22-2005, 05:58 PM
Anyone have the same problem and able to fix it???
Old 02-22-2005, 08:56 PM
gspotter's Avatar
Those sub amps often will simply ruin the AM radio reception. FM should still be OK.
Old 02-24-2005, 05:19 AM
DiamondGCoupe's Avatar
MyG37 Administrator
Same problem after i installed my system, does it affect XM or Sirius reception?
Old 02-24-2005, 10:23 AM
No one has posted a solution? It would be great if someone could figure out why/how to fix this issue. I actually enjoy listening to the radio sometimes, but this is a real drag.
Old 02-24-2005, 12:42 PM
MyG37 Administrator
Remount the amp somewhere else in the car.
Quick Reply: Anyone know where the stock antenna is?
