aftermarket wheels 18 inch
Old Mar 26, 2016 | 12:16 AM
edin_g35's Avatar
i have 2005 infiniti g35 sedan 6speed rwd with factory 18x7.5 wheels offset 45 all four corners. i just bought aftermarket esm 007 18x8.5 offset 35 front and 18x9.5 offset 40 rear. can 18x9.5 with offset 40 work good on rear? i am not planning to lower car at all. just keeping factory ride height. tire size on front is gonna be 255-40-18 and rear is gonna be also 275-40-18. any help/comments gladly welcome. thanks!
Old Mar 26, 2016 | 09:49 AM
DailyDrivenCoupe's Avatar
if you are not lowering the car at all then you should not have any issues rubbing on that size tire. im currently running a very similar setup and im still using a 20 mm spacer to make it a little more flush
sparky465
Apr 10, 2016 02:23 PM
ivantheterrible
Feb 1, 2016 09:47 AM
Aaroncg28
Jan 31, 2016 01:09 PM
jayd33-
Jan 30, 2016 03:12 PM
