12v outlet stays on when car is off?
Old Mar 2, 2018 | 11:30 AM
foraben's Avatar
The 12v power outlet in my 05 sedan constantly stays on, even when the car is off. It powers my dashcam and radar, and I don't want them draining the battery overnight.
Any ideas?
Old Mar 2, 2018 | 12:08 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I think it only stays on for 20 minutes, you can time it to be sure.
Old Mar 2, 2018 | 05:44 PM
foraben's Avatar
It was still on when I came out to the car this morning after 8 hours unfortunately. Not sure what's up because my 04 never had this problem
Old Mar 2, 2018 | 11:00 PM
cleric670's Avatar
BANNED!!!
Do you have multiple 12v outlets? Typically the ones designated as "cigarette lighters" will be full time powered, ones designated as "12v outlets" will be relay controlled to timer off after ignition has been shut off.
Old Mar 3, 2018 | 08:16 AM
FreshLikeAG's Avatar
I only get power to the cigarette lighter with the ignition on. Sedan may be different
You may want to consider hardwiring a voltage cutoff if you plan on leaving things plugged in. It will cut off power once the volts get too low so it won't drain your battery. Usually you can set the limit. Some dashcams have them built in
jcrayamsterdam
V36 Audio, Video & Electronics
Feb 7, 2011 01:39 PM
BJD275
Lighting
14
May 29, 2008 08:16 PM
Christopher____
V36 General Tech Questions
May 15, 2008 05:27 PM
iafzal
Dec 2, 2004 07:25 PM
