Fried Yaw Sensor Power Wire
Old Oct 24, 2018 | 04:36 PM
  #31
CrustyMilkBagz's Avatar
6mt
Forgot to include diagram
Old Oct 24, 2018 | 05:17 PM
  #32
6mt
Also double checked fuse 88 in the ipdm after that, the one that sends power to the vdc control unit and it was fine
Old Oct 24, 2018 | 06:38 PM
  #33
6mt
Woow so i figured it out and made the switch work with power from the obd port. Basically my switch has 3 prongs. One power one acc and one ground. I had the orange wire going through power and ground and my ground for the light on the acc prong so basically it was letting too much current flow and blowing the fuse. Switched the orange wire onto the power and acc prongs and my ground onto the ground prong and everything works no blowing fuses. Smh lol thanks so much for all the help though everyone
Old Oct 24, 2018 | 07:47 PM
  #34
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Awesome, glad you got it all worked out.
Old Oct 24, 2018 | 08:04 PM
  #35
6mt
thanks a lot ! Take care
Old Oct 24, 2018 | 09:39 PM
  #36
Urbanengineer's Avatar
Thanks for sharing. This will serve as a great resource in the future!
Old Sep 4, 2020 | 09:48 AM
  #37
G3505DEUser's Avatar
g35
Help please!
So I have a 05 coupe. Having similar issue. Orange wire stopped lighting up my switch. I tried connecting it back to the oem one and doesn't do anything. Went and bought another switch still not working. Are you saying u had the connections connected to the wrong prong? Because mine were connected correctly and it still stopped working even after i bought a new switch . Do I need to splice a new power wire to the vdc connector from the obd port? Or possibly just a fuse?!
Old Nov 2, 2020 | 08:35 AM
  #38
Cornercarver's Avatar
FBO
Hello all. I too had this problem with my 05 model. During testing, I fried the orange wire (or fuse which I have yet to find, but your info is promising). Here is what I did to repair mine: I ended up tapping into my heated seats 12v supply (dark green wire with red tracer--there are two of them) and the system works flawlessly. The downside to this mod, as previously mentioned, is that once activated, it stays in the disabled mode until the ignition switch has been reset (off and back on), but functionality is consistent and predictable, which is all I wanted. I am also using a 7.5 amp fuse, tapped into a clever little stand-alone protected fuse block I picked up at the local APS for 10 bucks, that tucks neatly into the recess under the ash tray. I ended up with a reliable, tidy installation. For those of you who are considering the YAW disable mod, I still recommend an in-line fuse, to prevent frying the power supply to the yaw in the first place, but the green wires with red tracers from the heated seats are right in the vicinity of the original YAW Power supply, so fishing wires through the interior is not necessary if you do as I did, and destroy the original power feed.
Ben Northway
Interior
Apr 17, 2013 04:59 PM
dddragon2
Aug 26, 2009 04:13 PM
rnak341
Jan 26, 2009 03:20 AM
BBart
Aug 31, 2006 11:02 AM
mrdigital
Oct 20, 2005 12:28 AM
