Ecu help for manual swap
Old Nov 7, 2024 | 10:39 PM
Cbrayden's Avatar
07 g35 6 speed swap rear wheel drive was all wheel drive
Need help
Recently just got an 07 g35 originally auto awd- now 6 speed rwd, my question is, in first and halfway through second gear it has no *** at all , but at about 3500rpms in second it comes alive, guy I got it from said it still has automatic ecu and was wondering if that would be making it weak in first and second? Do I need to do the pure and retune my ecu?
Old Nov 8, 2024 | 01:26 AM
05_SkylineSedan's Avatar
20 Year Member
Maybe check to see if the rear diff is the correct one? Just a wild guess but I know sometimes auto / manual require different rear-end gear ratios.
Old Nov 8, 2024 | 10:57 AM
seymore4's Avatar
m56
You do need a tune, but I think there's also something else going on. PM/email me when you're ready I've done a ton of these tunes.
Old Feb 18, 2025 | 05:28 PM
chelton22's Avatar
needing a ecu tune or flash
Help
I’m getting the u1000 code as well but my car runs fine after the swap, it’s just having communication issues. Nowhere even want to make a tune or flash the ecu for me . Have yall heard of the ones the are programmed to plug and play
Old Feb 18, 2025 | 05:43 PM
seymore4's Avatar
m56
I can tune it no problem
Old Apr 7, 2025 | 08:36 AM
VQDZA's Avatar
Fried 6mt ecu
No, we can load a new license onto it over email. Used cable does save you some money!
hey dude same here I tried messaging you but I can’t. I think my ecu might be fried (no codes, good voltage all the way to the coils, new hitachi sensors fuel assembly IPDM fusible etc, I believe it’s not in anti theft mode but I can’t change maps even though CC works, but there was frozen water under my battery and the grommet is worn). I’m thinking about testing another but I can’t find a stock manual in the time frame I need so I’m getting one from an auto.
my car:
05 6mt de swapped engine original rev up harness and tuned by Moncef
donor:
05 g35x (I believe these don’t have rev up right only 6mt g35 and 350z?) de
Can I reprogram the auto ecu to manual? Also is it possible to move my license over or do I just have to retune the new ecu? At the minimum I wanna start the car and be able to drive again I can worry about my tune later maybe even fix the original ecu. I have NDSII UpRev (the non tuner version) and both cables
Old Apr 7, 2025 | 10:43 AM
seymore4's Avatar
m56
Email me-- seymore4 @ gmail
pure sex
Tuner & Dyno
24
Jun 22, 2024 11:12 AM
Josh_Q
Apr 28, 2023 11:16 AM
Mpstelmack98
Jan 6, 2019 11:57 AM
Hypnopirate
May 1, 2018 01:52 PM
