Door locks not working
Old Jan 22, 2022 | 03:56 AM
Dedsec1345's Avatar
G35x
Tried to go to work and my doors struggled to open, then when I got in the doors wouldn't close. Tried to fidget with the lock on the door with my fingers and it closed, but now won't open no matter if I hit lock and unlock, had to crawl out the passenger side and that door won't close now. I'm very bad with electrical work so I have no idea what it could be.
​​​​​​IT WAS 0 DEGREES OUTSIDE IF THAT HAD ANYTHING TO DO WITH IT
Old Jan 22, 2022 | 11:24 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yes it's definitely possible that your latching mechanism is frozen up, do the rest of the doors work properly?
You can remove the door exterior and interior panel to inspect for any problems with the linkage or latching mechanism, it's not a common issue for the latching mechanism to fail but it does happen occasionally.
Just to verify the HINGE is working properly yes? It's just that the latching mechanism won't function properly?
Old Jan 24, 2022 | 02:07 AM
909's Avatar
909
Your mom's boyfriend
Absolutely do not wash your car when it's below freezing.
Try your best to not allow water near your driver's side door in general, if it can be prevented.
You can apply heat from the interior with a space heater or hair dryer which might help or might not
It's best to remove the interior door panel . Once you can see inside you'll know exactly what the problem is and how to fix it.
To open the door, remove your window trim from the interior and use a long stiff wire with a bend / hook at the end.
Old Jan 24, 2022 | 05:17 AM
Scorpi0's Avatar
Just leave the doors closed and crawl in and out through the sunroof
Youredumbbro
Jan 7, 2020 01:02 PM
Ryan1979nz
Aug 3, 2014 07:43 AM
NGreeeeeen
Interior
Apr 7, 2011 09:23 PM
nctrnlsilvia
Interior
Dec 31, 2008 10:52 PM
GHBG35
May 16, 2005 06:33 PM
