how do you improve the sound quality of an aftermarket sirius unit
Old Mar 31, 2005 | 03:52 PM
baomao123's Avatar
I have a 2003 laser red coupe. I did not get the dealer sirius/xm radio option. However, I decided much later on to buy an aftermarket sirius unit. The unit has a built in fm modulator; thus, all I have to do is plug it in and mount the antenna. I've had the unit for like a year now and have not been impressed by the sound quality. I've tried to change the frequencies/channels but nothing really improve the sound quality. The lack of clarity is really apparent when there is a high note.
My question is, is there a way to improve the sound quality of an aftermarket unit such as my sirius audiovox, such as hardwiring it to the stock BOSE? If anyone has done something similar to this, please inform me of what parts you used, how much did it cost, and if you DID NOT do the install yourself how much were you charged for the installation.
Thanks so much for your inputs.
Old Mar 31, 2005 | 04:46 PM
ikSardarG's Avatar
Ok,
If the aftermarket sat unit has a headphone out, or better yet - a line-out... I would try and see if you can install the PAC AAI-NIS unit. Does your Bose headunit have the SAT button? If so - it would be easy to add a real aux in to the headunit, and having the sat radio run through the headunit. The sound quality will be 100% better - and will be close to that of your CD player.
So the connection will be:
Your SAT radio --> The PAC AAI-NIS --> output through your stereo via Bose headunit
If you need help getting a PAC unit - I can help you out. Thanks.
Old Mar 31, 2005 | 04:51 PM
G2G's Avatar
G2G
Do you have to tear apart your dash to connect the PAC AAI-NIS part? I have the same problem but I have a XM roady that has the line out option.
Old Mar 31, 2005 | 04:58 PM
ikSardarG's Avatar
Hmm... In a sense, yes you do. But if you read-up on the disassembly process and you prepare yourself - it isnt that big of a deal. You have to get behind the stereo to access the port for the PAC unit... It means taking out the AC/Stereo area to get to it.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
TWASkyliner
Feb 8, 2020 08:00 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
kd03g99
Jul 30, 2015 11:24 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
