4080s subwoof box
Rating: Thread Rating: 4 votes, 4.75 average.
Old Apr 30, 2005 | 08:46 PM
  #46
shooter's Avatar
It's not the critic......
Just wanted to post a pic of my new grill cover for my modified 4080 enclosure...........i used a diamond audio 10" sub and it has a HUGE magnet and would not sit flush on the original mdf ring......so i made a 1/2 inch spacer ring and glued and screwed it to the original.......the movement of the diamond audio sub was too much and it would kick the original grill off......so i talked to 4080 and he made me a deep grill with an extra 1/2" clearance......THANKS 4080......great customer service!
Old May 2, 2005 | 01:38 PM
  #47
Pearlcoupeg35's Avatar
4080, is your coupe box only on the drivers side? or can i get one on each side? id like to throw two 10s in the trunk...one on each side...lemme know..
Also, for those with this box, whered ya mount your amps???
Thanks.
Old May 2, 2005 | 10:41 PM
  #48
4080's Avatar
Thanks.
The only build the box for the driver side. The pass. side of the trunk has a fuel neck that takes up air space. If I built a box for the pass. side to match the driver side it would be smaller. This can cause one woofer to be louder, play lower, and handle less power than the other woofer. I would suggest that you invest in one quality woofer and amp combo. Out of 120+ boxes sold, I have never had a customer say that one woofer was not loud enough. Most guys mount the amp on the back of the back seat. I have my amp mounted under the rear deck. Here is a pic.
4080
Old May 2, 2005 | 11:10 PM
  #49
Skkyy's Avatar
What's the cubic feet of the box?
Old May 3, 2005 | 01:04 AM
  #50
FasterThanThem's Avatar
first post going to get 4 more then pm you 4080
Old May 3, 2005 | 01:14 AM
  #51
Thats five, I've pm'd you 4080 if you cannot pm me back
please consider shooting me an email
Craig@fasterthanthem.com
I've had my coupe for 5 hours and I allready cannot stand the no sub situation.
thank you
Old May 3, 2005 | 01:32 AM
  #52
crai6m4ck's Avatar
Send me some info!!! Price, Etc... PM or crai6m4ck@hotmail.com
Old May 3, 2005 | 12:02 PM
  #53
jaspergtr's Avatar
i'm going to go off on a limb here...
4080 - do you recommend any particular sub for both the 10" and 12" box for the sedan? i do not have a full size spare.
Old May 3, 2005 | 05:10 PM
  #54
05GRide's Avatar
4080
Can you also PM me with some specs on these boxes? Price, air space, mounting depth, etc etc. Thanks.
Old May 3, 2005 | 05:24 PM
  #55
Mantanegra's Avatar
how much for 4080
Old May 3, 2005 | 10:42 PM
  #56
4080's Avatar
Internal air space volume is .85cuft.
thanks, 4080
Old May 3, 2005 | 10:48 PM
  #57
4080's Avatar
It depends on how much money and bass you want. I am perfectly fine with a JL 10W0. It sounds awsome and is cheap. But since I knew some guys wanted to listen to my car loud I went with a larger Rockford P3. The JL 10W6V2 is the most popular and is my suggestion.
Thanks, 4080
Old May 3, 2005 | 10:50 PM
  #58
4080's Avatar
Originally Posted by Mantanegra
how much for 4080
I tried to send you a PM but you must be new. Give me your email address
4080
Old May 4, 2005 | 01:10 AM
  #59
6mt/brembo's Avatar
I need a price for the 4080 box thanks
Old May 4, 2005 | 01:20 AM
  #60
crai6m4ck's Avatar
Hey 4080, Try PMing me again. My mailbox was full and I didn't receive your message. THANKS!!!
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
