Sound Deadening the G.
Old Mar 12, 2009 | 04:32 PM
  #136
The Stimulation's Avatar
Originally Posted by blazeplacid
id be careful with edead hanging like that
I have bad expericances with edead sideways on the rear quater panel, in the summer time the adhesive gives and you may be havingto clean up some goo
I personally don't like eDead, but if it's butyl based and not asphalt then you don't have the peeling issue as much. I dislike Fatmat since it is asphalt based and will melt and peel under high heat temps.
Old Mar 12, 2009 | 09:07 PM
  #137
releasedtruth's Avatar
Fatmat is definitely inferior and I would not recommend it. I used it on one car, not ideal. It's thin, smells and holds like crap. I do offer thumbs up on raammat bxt60. 60mil thick, butyl and the value seems to be quite good.
Old Mar 12, 2009 | 09:27 PM
  #138
StreetChase's Avatar
I put the cover back over top of that. It actually looks like this now:
Old Mar 12, 2009 | 11:27 PM
  #139
dreamweaver's Avatar
FYI found this site for some neat sound deadner....
http://www.secondskinaudio.com/
Old Mar 13, 2009 | 10:53 AM
  #140
The best sound deadener IMO
Old Mar 13, 2009 | 05:31 PM
  #141
Well I picked up a can of that BIg Gap Filler stuff and used the entire can on my trunk. I still have a decent sized void to fill though. Ill let the foam cure over night and then pick up another can tomorrow to finish the rest.
Old Apr 9, 2009 | 10:11 AM
  #142
Since I had the whole rear out I thought I'd fill the panel voids while I was at it so I got some fiberglass insulation and filled it in... I thought it would make a significant difference and it does in a way, but the downside sucks.
Now I have a high pitched whine from those panels on each side. It was more or less an exhaust resonance chamber before so now when the car is on, it whines, even in park. Almost more annoying than the alternative. Just keep wasting time on solutions that don't work for me.
Old May 10, 2009 | 01:59 PM
  #143
Strtsk8r321's Avatar
I used the exact same Dap Tex foam insulator as the original poster and like a week later on a hot day it all started leaking out my trunk and going all over the place!
How do I get this stuff to harden? Im so frustrated I dont know what to do now! Can anyone give me some advice?
Old May 12, 2009 | 02:43 PM
  #144
zeadlots's Avatar
Did you read this post?
https://g35driver.com/forums/4005118-post129.html
Old May 12, 2009 | 03:11 PM
  #145
blazeplacid's Avatar
probably ashphalt based stuff
any deadner made of asphalt is gonna melt in the summer heat
days/weeks of temps over 90º will make the stuff come right off
Old May 17, 2009 | 04:50 PM
  #146
shoot....what should I do to get it out...?
Old May 18, 2009 | 12:25 PM
  #147
contact the manufacturer and get an MSDS
it may tell you how to remove it
deadner is supposda stay for ever.......
Old May 19, 2009 | 11:21 AM
  #148
slizzap's Avatar
For those of you that deadened the front doors, how exactly did you do the inside of the exterior panel? There's 2 horizontal bars on the door itself, so I used raammat and put 2 layers of 3 horizontal strips on the door - above the bar, between the bars, and the very bottom below the bar. When I knock on the outside of the door it definitely produces a "thud" like the other panels I've done and it sounds better, but the door itself still resonates. I's definitely more solid but I thought the deadening material is supposed to prevent the resonating as well, and I haven't heard anyone mention anything about that regarding the door. I assume this is primarily because of those horizontal bars and that you can't put one solid layer on the door. Figured I'd try and get some feedback while the panels are still off my door.
Old May 19, 2009 | 11:45 AM
  #149
you can go at it two ways
you can try to snake your hands around and apply it where you can
or you can take the inside panel off including the window motor and such.....
Old May 19, 2009 | 12:00 PM
  #150
slizzap's Avatar
I assume you're replying to me since you mentioned the window motor. I completely removed the glass and the motor/panel. I already covered as much of the door as I could get to with 2 layers. If I recall I had 46" long strips covering each area above, between, and below the bars. That's basically the entire length of the door. Just to give you an idea of how much area I covered. But when I knock on the outside, I get the "thud" I'm supposed to but the panel resonates. Just put your ear up to the panel when you knock on it, or if you car's clean and you have a good reflection of light off your panel you'll see it resonate as well. I was just curious if anyone else noticed this. I'm going to do the driver side door tonite so I wanted to check beforehand in case I could've done something better.
