Problem w/my PAC
Old Apr 17, 2005 | 03:51 PM
melodicskys's Avatar
Problem w/my PAC
I finally got all my gear installed (PAC, Belikin Auto Kit) and it works great except that my HU wont recognize the PAC unit as a SAT unless I have my cell phone charger pluged into the arm rest 12v supply. I can unplugg it once the HU is changed to SR1 and it continues to work, but it just wont recognize it unless it's plugged in. The only correlation the arm rest 12v has to the sytem is that is the line that I tapped into for the Belkin Auto Kit 12v supply, but that is still supplied with power even when nothing is plugged into the arm rest 12v socket, so why this is happening has got me thourghouly confused.
Any ideas?
Old Apr 18, 2005 | 10:26 AM
rcdash's Avatar
I tapped into the armrest also on my 2004.5 Coupe. No problems - nothing plugged in to the 12v socket.
All I can think of is that it is a bad splice? Maybe the wire is almost cut in half? No idea why it works when you start to pull juice through the 12v socket...
Old Apr 18, 2005 | 12:29 PM
P_Diddy's Avatar
A possibility could be that your splice is bad, and when you plug in the charger, it pushes out on the 12v housing and completes the connection.
You guys have a 12v socket in the armrest? Is that 5AT only? I don't have one there, only 2 on either side of the dash.
Old Apr 18, 2005 | 12:45 PM
the splice is about 3 inches away from the actual 12v socket just in the middle of the line. and it maintains power to the belkin unit after my HU recognizes the PAC if i pull out my charger from the socket. This is very reproducable, but i cannot for the life of me figure out why.
aslo i have a '05 5AT and there is one in the armrest and one under the HU
Old Apr 18, 2005 | 12:53 PM
Potty_Pants's Avatar
screw splicing it into an existing line... might cause problems as you are stating...
secure the ground to the chassis.
then run the hot line to the fuse panel. extract a fuse (prob the same one for the lighter) and place the wire across the female connector... then push the fuse into the female connector. good,safe & easy disable connection.
gl
ppp
Old Apr 18, 2005 | 01:12 PM
rcdash's Avatar
The other thing to consider given that it works after there is an audio signal is that the PAC is bad. There's not much to mess up in the wiring, unless you're hooking up a SWI-X or something else also (even then, instructions are pretty straightforward).
Or I hate to say it - it's not plugged in properly behind the HU? That's alot of effort to go through to check it - but can't think of anything else...
I would just order another one and tell your vendor that yours doesn't work right. Then just go through the install again and replace it.
Old Apr 18, 2005 | 01:16 PM
not going to be that easy, plus i paid for the install, fortunatly i charge my phone in the arm rest so the charge is staying put for now, its just so weird that the Belkin that is powered by the same line as the phone charger somehow affects the HUs ability to see the PAC.. arg.. i don't see the relation.
Old Apr 18, 2005 | 06:14 PM
rcdash's Avatar
I would send a note to PAC Audio and see if they have any comments... Unlikely that they'll have an answer, but they do respond to e-mail.
Old Apr 18, 2005 | 07:32 PM
the good news is that i love the setup I will post pictures tomorrow of how i mounted everything since i haven't seen anyone do it the way i choose.
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
