Capacitor suggestions
Old Apr 22, 2005 | 10:11 AM
aznluder's Avatar
Florida G35 Club Premier Member
Ok, my system will be running a JL 500.1 and JL 300.4. How big of a capacitor should I get? Is 1 farad enough, or should I go with 2 or 3? Also, who makes a good digital capacitor? Thanks.
Old Apr 22, 2005 | 11:02 AM
amg35's Avatar
Florida G35 Club
1-F is enough. Plenty of good caps out there. Check out the manufacturer of the power cable you are using. Alumacap, Stinger, DEI, etc. Good luck, sounds like the makings of an awesome sounding system.
Old Apr 22, 2005 | 11:12 AM
aznluder's Avatar
Thanks. I've used Lightning Audio caps in the past and it worked fine. I may just get a Stinger cap just because it looks nice. Thanks again for the advice.
Old Apr 22, 2005 | 07:25 PM
supsup's Avatar
how will u connect the cap to ur mono?
cos i see many ppl with different ways to do it!
do i have to charge it before use?
tell me how u get it all work out right!
thanks!!!
Old Apr 22, 2005 | 08:02 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
-normal rule of thumb is 1 Fa for every 1000W of power
-charging a cap depends on which model you get, but most caps will need to be "charged". Instructions come included on how to do this
-i only know one way to wire. a power wire coming from your battery or distribution block to the (+) terminal on your cap, another power wire from that same (+) terminal to your amp. (-) of the cap to ground.
that's how i plan to wire my set-up.
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
Rose M
Oct 12, 2015 10:00 AM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
