What speakers fit in the rear panel (6.5")?
Old Jun 7, 2005 | 09:41 AM
g8tor20's Avatar
FGC's official flip flopper
I have searched this to death and haven't found the exact answer...so here it goes:
I know the depth is shallow on the rear panel (not the rear shelf 6X9) and some 6.5" speakers dont fit.
What is the maximum depth of the speaker for it to still fit?
Can you guys give me some examples of some good speakers that fit there?
Thanks
Old Jun 7, 2005 | 11:42 AM
Rudy's Avatar
Sound Advice
Most will fit but you will need a 3/4" spacer. MDF works well.
Old Jun 7, 2005 | 12:34 PM
magnetism80's Avatar
I think Rudy is right. Most will fit it depends on how good your installer is. There is a post saying that Infinity Kappa 63.5i will not fit. THIS IS WRONG!! I just had a pair installed at my local Tweeter on Sunday. The installer did say something about using some kinda ring or something, but he did get them to fit. I beleive that any speaker 2.5inches or shallower will fit. The Kappas are 2 5/16" or 2 3/16", cant remember..Anyway they fit..hopw this helps
Old Jun 7, 2005 | 01:12 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
There is a metal brace that inhibits the mounting depth of the back seat side panel. There was a post that you can get around that by placing a 2x4" on the metal brace and hammering the 2x4" towards the outside of the car to collapse the brace. This will give you adequate depth.
I was the one that posted that my 63.5i's would not fit and I settled for Eclipse 6.5"s that were shallower but this was before I knew that you could get around that brace.
hope this helps...
doc
Old Jun 7, 2005 | 01:44 PM
rcdash's Avatar
I installed diamond audio M-361i in the rear and they have a mounting depth of 2.5". I did not need to bang the metal behind (but it's not a bad idea now that it's mentioned). I did need to space the speaker forward about 1.25 inches (I used the stock metal ring and long bolts) so that it was positioned in the same spot as the stock Bose - flush with the covering panel. This barely left enough room in the back.
Old Sep 6, 2005 | 08:02 PM
djpj79's Avatar
Anybody think these will fit in the rear side speaker panels? (05' Coupe)
http://edesignaudio.com/product.php?...=Specs&cur=USD
mounting depth = 3.6"
I want to power these with a NINe.2X as Midbass speakers along with a set of eDi-6500s powered by another NINe.2X in front doors.
http://edesignaudio.com/product.php?...pid=29&cur=USD
or maybe I should put the EU-700s in the rear deck? what do you think Rudy?
Thanks!
-Peter
Old Sep 6, 2005 | 08:19 PM
G35ZRUSH's Avatar
Old Sep 7, 2005 | 12:45 AM
djpj79's Avatar
Originally Posted by g35zrush
5.25
huh?
Old Sep 7, 2005 | 01:03 AM
realgone's Avatar
Widdle ya into kindling
If my installer friend ever gets around to it, I have a set of Mb Q's for the rear. Hope he can get them to fit.
Old Sep 7, 2005 | 09:22 AM
Espresso's Avatar
Thanks!
-Peter
I definately don't think the EU-700s will fit even with modifications. You can add spacers to get that mounting depth but once you put the panel back on, the speakers might end up touching the panel and viberate.
mjfenix
Aug 17, 2017 05:49 AM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
tiguy99
Mar 1, 2016 11:42 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
