sirius to xm
Old Jun 16, 2005 | 07:16 PM
opimax's Avatar
still want to trade, i like Sirius programing music better...
Mark
Old Jun 21, 2005 | 12:46 PM
pingo's Avatar
My Sirius and XM antennas both work with each other on my Plug and Play sat radios. Don't know about the factory units in the trunk...Pingo
Old Mar 29, 2008 | 12:45 PM
Offtrac's Avatar
Has this been rectified yet?
Will my stock sirius anteanna work with a XM receiver If i swap recievers?
Old Apr 18, 2008 | 02:33 PM
Offtrac's Avatar
bummp
Old Apr 18, 2008 | 08:29 PM
06slvrG's Avatar
I did just the opposite of you. My car came with XM and I wanted Sirius. I bought the tuner from Everything G35 and put it in myself. I was hoping to use the antenna already installed on my car (the xm one), but it did not fit the Sirius tuner. I then tried to cut the end off of it and put on the end of an old Sirius antenna I had laying around. I soldered it on and it connected fine, but it did not work. So, in the end I had to take the XM antenna off the roof and put the Sirius one on. It wasn't too hard. Just let the car heat up to help break the glue's grip. Then just run your new wire where the old one was. It wasn't as bad as I thought it would be. The hardest part is getting the antenna to break free (it is both glued on and a has a magnet base). Be careful not to scratch your car, especially if you don't plan on putting the new antenna in the same spot.
Old Apr 18, 2008 | 08:41 PM
kernel's Avatar
SEC > Big 12
why don't u just wait a while till the merger is complete.
Old Apr 18, 2008 | 09:20 PM
Offtrac's Avatar
Thanks, thats what I needed to know..
Old Apr 18, 2008 | 09:21 PM
Offtrac's Avatar
I bet even after the merger, they will remain seperate entities and not swap like that
wuppiedog
Aug 7, 2015 11:16 AM
kkDude
Oct 28, 2004 02:27 PM
blanduyt
Feb 27, 2004 03:35 PM
prabhacar
Feb 10, 2004 09:48 PM
Jedi
Apr 14, 2003 12:18 PM
