i need help with system on stock hu =(
Old Jun 19, 2005 | 11:46 AM
yonimation's Avatar
hey guys, so i got my kicker 10" and kx 550.2 installed running on a stock hu and i have the bose amp. the system hits but it hits poorly. i know the kicker can do 80% better than wt is bumping. can anyone help? maybe on how to bridge the wires? or how or where should the converter be connected? or anything? by the way the sub is a 4ohm dual and the amp specs is bridged rms @ 4ohms at 550w x1. ANY ANY help would be greatly appreciated. i tried using the search but found things i dont think concerns this matter. thank you
Old Jun 19, 2005 | 12:28 PM
Glex25's Avatar
Administrator
I say run the LOC after the Bose Amp.
run the voice coil in parallel and bridge your amp and it should sound better.
Properly adjust your gains
Old Jun 19, 2005 | 01:26 PM
IS300TOG35's Avatar
► Matt ◄
I feel like a tard asking this but what is a LOC?
Old Jun 19, 2005 | 01:54 PM
Glex25's Avatar
Administrator
Line Output Converter=convert reg speaker wires(High) to RCA's(Low)
Old Jun 19, 2005 | 02:50 PM
IS300TOG35's Avatar
► Matt ◄
Thanks
Old Jun 19, 2005 | 10:08 PM
mr_ecktid's Avatar
Why would you say install the LOC after the Bose amp? I've read that it was better to do it before the amp...
-Mark
Old Jun 22, 2005 | 12:27 PM
realgone's Avatar
Widdle ya into kindling
Just do the double din conversion. I originally went with an LOC, but got noise. Within a month I took the car to the shop and had the conversion done. It sounds way better.
TWASkyliner
Feb 8, 2020 08:00 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
joedaddy1
Jul 28, 2015 02:58 PM
