gettin to the hu
Old Jun 26, 2005 | 11:21 AM
JEAThirty5's Avatar
gettin to the hu
i have an 05 g35s and im following docrons guide
im stuck on this part
my cup holder isnt attached to the same place
help please
Old Jun 26, 2005 | 11:39 AM
g35driver05's Avatar
All you have to do is 1. take off the shift **** 2. Just Push down on the Black plastic where it meets the alum. trim. (behind the alum trim.) This will disingage the metal clips. Or use a small screwdriver. but be careful not to stract it. One those 2 clips are off just move the shifter to Neutral, then pry up the trim.. it comes off very eazy..
Hope that helps.
Old Jun 26, 2005 | 11:56 AM
Gee Im Fast's Avatar
You workin on an AT or MT?
Old Jun 26, 2005 | 12:04 PM
JEAThirty5's Avatar
sorry i have teh "willow" interior would you mind describing in willo terms please
Old Jun 26, 2005 | 12:05 PM
JEAThirty5's Avatar
AT sir
Old Jun 26, 2005 | 12:08 PM
BlackonBlackG35's Avatar
On the 05 all you need to do is remove the shift **** put it neutral and then pull up on the shifter assembly....
It should look like this when removed....well sort of.
Old Jun 26, 2005 | 12:19 PM
JEAThirty5's Avatar
ty is the end of it a bit harder to pull off? seems to be a sticklr
do i pull up or at myself
Old Jun 26, 2005 | 12:33 PM
Pull up on the front by putting something flat underneath (I used flat screwdriver) and pull towards yourself for the back part, make sure it in neutral other wise it will not come off....
Old Jun 26, 2005 | 01:40 PM
JEAThirty5's Avatar
wtf teh screw on the left aint budging its like glued down :-\
i went for that one first too
Old Jun 26, 2005 | 03:38 PM
JEAThirty5's Avatar
dewalt <3
KEVIN97A4
May 18, 2005 02:34 AM
Sundeviljay
May 10, 2005 12:59 PM
kame_san0
Apr 28, 2005 01:19 AM
EX250
Apr 8, 2004 06:31 PM
