Sedan trunk area ground point..
Old Jul 25, 2005 | 04:42 PM
khsonic03's Avatar
Here is a quick one:
http://www.the12volt.com/installbay/...TID=49445&PN=1
Here is a LONG one:
http://www.the12volt.com/installbay/...TID=37762&PN=1
Old Jul 25, 2005 | 05:15 PM
G35_TX's Avatar
This just backs my statement up that the shorter the ground the better. 4-6 inches or less to a clean spot on the frame. The longer the wire, the more resistance, the more chance of problems.
Old Jul 25, 2005 | 05:42 PM
Texasscout's Avatar
Ok guys. I've read enough of this grounding crap. Taking a wire from whatever you want to ground and attaching it to the frame(Bare metal) is not a real ground.
To completely ground your system, you should hook up a ground wire from the part and connect it to the negative terminal on the battery. This will give you a complete/Proper ground.
It is a common mis-conception that the ground and negative wires are different. This is not true. They are one and the same.
BTW, I am an electrician. The ground and negative on a 110~130V house lead to the same place. It is just because of the Electrical Code that these two wires are kept separate until they reach the breaker/fuse box.
This is the ONLY guy who made sense on that thread
This guy just proves MY point, you must have a wire to the battery. If you use 0 gauge on the pos. side and use the body on the other, you are not balancing the equation.
To add to this, a good ground for car audio applications will have a return resistance reading of 1/2 ohm or less. I have yet to have a return reading of 0 ohms. If a ground return reading cannot be made to get below 1/2 ohm by means of the "BIG 3", then it is adviseable to ground direct to the battery. Electricity is an algebra equation, what you do to one side you must do to the other. Pay as much attention to the ground wire as you do the power wire.
I guess we will have to agree to dis-agree on this....
Old Jul 25, 2005 | 10:36 PM
khsonic03's Avatar
I was kinda getting at the latter of those two quotes. He states that if you cannot get a good ground with the "big 3", then ground direct to the battery. That guy has about 3500 posts, and seems to be pretty knowledgable on the subject. I think that in most instances, grounding with the big 3 will be fine, but in some cases, it is necesary to ground direct to the battery. But there is certainly NOTHING wrong with grounding direct to the battery. If anything, it is a sure-fire way to go.
Old Jul 29, 2005 | 12:00 PM
deenice21's Avatar
when you say you must have a wire to the battery , that is true, but realize that there are alreardy wires that are going to the negative terminal and are also touching the frame. so actually the wire that is touching the metal in the trunk ,is touching the metal in the engine ,that is touching the wire, that is touching the negative terminal.
Old Jul 29, 2005 | 03:45 PM
khsonic03's Avatar
Ummm....yeah I think we got that. We were arguing...ehem..."discussing" whether or not it was better to run a ground directly from the amp to the battery. There can be resistance in the chasis/frame of a vehicle that can impede the flow of the ground; especially when there are several devices all grounded to the chasis.
Old Jul 30, 2005 | 08:28 PM
amg35's Avatar
Florida G35 Club
The best ground is the one that allows the system to function properly. I have seen grounds in almost every location in numerous vehicles; the one that works is the best. Some like it short, some like it long, and some like it at the battery, I like the ground that works.
Old Jul 30, 2005 | 09:03 PM
Texasscout's Avatar
Coudn't have said it better myself!
tal1412
Nov 28, 2022 09:25 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
joedaddy1
Jul 28, 2015 02:58 PM
Ninjay16
Jul 20, 2015 01:21 AM
