Manual Shift Knob Removal
Old Jul 20, 2005 | 10:33 PM
Inno's Avatar
Manual Shift **** Removal
Ok this may be a STUPID question. I feel lame for asking. To start off, I did a DD conversion install myself. However, I still can't figure out how to get the Manual Shift **** off of my 05. I'm used to just twisting it counterclockwise (to the left).
Anyone know how to take the shift **** off a manual transmission 05?
Thanks!
Old Jul 20, 2005 | 11:00 PM
lowrider's Avatar
You need to snap up the trim piece on the bottom where the trim ring with the boot is located. Once you pop this piece up, you need to vice grip the shifter rod, so it wont move. You then need to have a large set of pliers and use a rubber insert to screw off the ****, while holding the vise grips to make sure the the shifter doesn't move. And yes, screw to the left. Some, mine was, are on pretty tight. They use some kind of thread locker and it can be hard to remove.
Lou
Old Aug 20, 2005 | 12:37 PM
HillBilly's Avatar
Dead Thread?
This might be a dead thread but I was looking for this info. Lou seems to have it right, just want to add the piece that pops up is the entire section of the console the ring attaches to (including the ashtray and hazard switch), the ring is held to the plastic with tabs and will not come off without breakage. I didn't break it but was thinking about it until I got the whole thing to pop off and viola'.
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
G35CO
Sep 4, 2015 09:27 AM
pasjr1972
Sep 1, 2015 10:17 PM
