DIY Speaker install on G35 sedan with non-bose
Old Dec 1, 2006 | 10:29 PM
  #31
ballisticus's Avatar
I just used this thread as a guide for putting in some Infinity 2-ways. Did it exactly the same way with the 3/4" MDF spacer and it worked great. I always thought the non-Bose OEM system was actually pretty decent for a base package, but now I know what I was missing.
I decided against the component route since my 40 year old ears probably can't hear the difference anyway. But for $139 shipped for 2 pairs of Infinity 6012i, it's the best money I've spent on the car yet. Incredible detail and imaging for a mass market coax.
I was amazed sitting in the center of the back seat how focused the soundstage is. The rear passengers are in for a treat. Now if I could just figure out a way to drive in the center of the car.
If you have a base system and need a weekend project, this is it. My only regret is not doing it sooner.
Old Dec 5, 2006 | 03:14 PM
  #32
falconey's Avatar
Originally Posted by khsonic03
LOL. Try again bud. Why do you think all home audio systems are 8 ohm? Re-read el-duderino's post. Bose uses lower ohms, because they can make crap amplifiers and still create an effect of a powerful system. When the speaker ohms are less, there is less dynamic headroom (musical peaks) and more distortion. Yes, if you are talking about the most bang for your buck, then 2 ohm is the way to go, which is why Bose uses them, but if you want SQ, at least 4 ohms is what you want.
SQ is compeletely opinion. What you may think is good SQ I might point my nose at. I in no way will ever make a claim that ohms translates into any type of SQ be it, good or bad. In terms of electric current and effeciency though I'm still going to say you want the lowest ohms possible. The reason most home systems are designed the way they are is because it's cheaper to make speakers that are durable and stable at 8ohms that it is to make speakers that are durable and stable at 2ohms etc. Another reason is industy standards. And finally it's not as important to be effecient electronically in a home than it is running off a 12 volt battery and 14.4 volt alternater.
As for what el dude says. That's his opionion and he could be right. Personally I'd think a company can make cheap equipment w/o having to worry about ohms etc. so I'd have to dismiss that logic this time. It's much more expensive to create a system at lower ohms and still be sure it's not only durable but also stable than it would be at higher ohms. That's just the facts. You will never find a 2ohm amp that pushes 300 watts RMS cheaper than an amp that pushes 300 watts at 4ohms. Same deal goes for speakers. Nothing's free including effeciency.
Still my words were a lil too harsh in my last post. I love debating so no worries.
Old Dec 5, 2006 | 07:16 PM
  #33
gramdacious's Avatar
Hmm. I just the broke the speaker out of the mount, dremeled/sanded it and put my Diamonds in. Works perfectly with a very tight seal. Free of charge, quick and easy. But if you wanna keep the sh$%ty speakers then obviously this is not the way to go. But you can Definatley use the stock mounts.
Old Dec 5, 2006 | 07:59 PM
  #34
Gilley's Avatar
I still want to know where to tap into the stock non-Bose wiring harness to get a signal for an amp and then to send it to the speakers. I really don't want to go through the molex connector.
Old Dec 6, 2006 | 08:36 AM
  #35
dovla's Avatar
Gilley, few days ago I cut the speaker wires above kick panel just before the molex connector, which I had to disconnect first in order to do so. These connectors are bitch and my hands are full of scratches from disconnecting and connecting them.
To OEM speaker wires I connected Monster XLN twisted pair using Posi-Lock connectors but the strands in OEM wires are too few and too tick for Posi-Lock to hold tight on them so after my hands heal I will replace them with some other kind of connectors.
I should have done this last year during DigitalWheelz screen installation while HU was out because it would be so much easier.
Old Dec 6, 2006 | 11:54 AM
  #36
Gilley's Avatar
Right, I don't want to bother with the molex connectors and would like to tap into the harness somwhere convenient near the fuse panel.
Old Feb 24, 2007 | 08:11 AM
  #37
CFaber's Avatar
back from the dead, but ...
has anybody else reused the factory speaker spacer? Is there a relatively easy way to break out the speaker and reuse the mount?
Old Feb 24, 2007 | 10:43 AM
  #38
Gilley's Avatar
I have read that some members have cut the Bose speaker out of it and used the plastic spacer. Of course, you can't reinstall the Bose speaker if you return to stock. It might be worth it to spend $20 to get spacers from www.zenclosures.com.
Old Mar 1, 2007 | 03:51 AM
  #39
dennyduong's Avatar
Is the speaker setup (non-bose) same in a coupe?
Old Mar 1, 2007 | 09:58 AM
  #40
Gilley's Avatar
What do you mean?
Jusseth
Sep 13, 2020 12:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
